zetec arp rod bolts?
yes you can re-use ARP rod bolts, before fitting them you measure the length and record it somewhere, then everytime you wish to re-use the bolts you simply measure them again and provided the anmount of stretch is still withing spec you can safely re-use them.
Colossal Pervert
That depends on your criteria. For 100,000 miles, then Ford quote 6400rpm with short burts of 6800rpm.
If you mean for doing a few thousand miles ragging it around the street or drag strip, then i'm sure regular use of 7000rpm will most likely be fine. If it's a n/a engine, then you can improve the tensile strength of the rod by getting it polished and shot-peened. Doesn't help much for forced induction though.
Colossal Pervert
SMILER258
28-09-2015 09:04 AM
