do u use a smaller plug gap on a big turbo??
saff is working!!!...atm
.........stu (msd) said something in a post the other day about wasted spark system and i was wondering if u have to use a smaller plug gap to prevent it "blowing out".....t38, t4, gt30,35 etc.............ta
The bigger the gap you can get it to jump the better but with all things there will have to be a compromise. The strength of your ignition system will determine ultimate gap size. Generally old systems(points, 1st/2nd HT setups) will have a smaller gap, coilpacked bigger then cdi's geet fucking huge gaps.
I'm running 1.0mm with no spark problems, drives better as well since I opened the gaps up from 0.65mm, but has given it a tendency to shunt a bit below 1500rpm in top which it didn't do before, but has not been fully mapped yet due to duff tps).
I am not using any external ignition amps though, so might be slightly different because of this but wouldn't of thought so.
Matt Baxter
16-09-2015 08:30 PM
Zoggon
10-08-2015 10:39 AM
Escortdriver1
31-07-2015 02:36 PM
