Wat brake pads, Do you like.
#42
Caraholic
Yes I tried the older compound on my Sapphire, and it was these that could lock up at mid-three figure speeds approaching a roundabout, with just 330mm / AP 4-pots .
You can't get them for my current callipers, as they are discontinued WRC items, so only a few companies do pads for them.
RW's was on DS3000s when I drove it IIRC .
#43
Ive put all my Racecar customers on mintex FR2 now , much better than DS3000 which has a good initial bite but doesn't last under race conditions . The F2 is a more durable compound and has received favourable reviews from several top runners including Nick williamson ( currently leading the LMA series ) , hes had 2 sets this season combined with F4 rear pads .
#45
Caraholic
Jim,
You just said the brakes were fanny-tastic, so why down-grade ? The trouble is that you will have got so used to the exceptional performance of the 97s and will find that any reduction in performance will either get you into trouble on track or will mean braking earlier etc.
#46
the 97s have a high temp range (MASSIVE!) but average friction co-efficient (similar to DS2500s iirc but they dont provide stats on it)
the 01s have a normal temp range (about 900degrees i think) but a higher friction co-ef.
so the 01s will offer me less fade resistance but more bite. As i don't need that extra fade resistance (i dont do endurance racing) you could consider the 01 compound an upgrade for my driving style.
#47
Caraholic
If you're unsure, then you could always try the 01s and see how they compare when you next need to change them .
#48
i USED to trail brake. i not stand on the pedal
i'll put the 01s in next time i need a pad chance which will probably be about a year, they wear REALLY well
