best rs turbo intercooler
just asking what peaples views on the the best all round intercoolers are please,the cars chipped,-31 actuater,exhaust and has a piper cam in head off his old engine.used one of the little pace jobs years ago but car got written off and then used one of the first grs full front versions on last rs but had real trouble keeping car cool.so any help and advice would be good as me brothers got his eye on an airtech frontal cooler cheers si
I had a GRS on my old turbo, seemed to work ok, apart from 2 things - the mounting tabs snapped loads of times and the car overheated like a bitch as the cooler blocked the rad.
The NMS intercooler seems an awesome bit of kit, no idea how much it is though?
i had a grs front mount but i sat it rite in the bumper.slightly trimmed the bumper but didnt cut whole thing out.left standard fan on rad.it had nice big gap between intercooler and rad that way to allow air in.had no problems like that
Have had GRS and Radtec setups and if anything GRS ran a little hotter. Ran about 30-35 more hp with Radtec as well...But purely for IC would say GRS.
As said though given the choice i would have the NMS jobby, or push the boat out and go with RS500 spec and a removable front panel
When you fit an I/C and rad you must have them sandwiched together without a gap in the between them as you are relying on pressure differences to allow the air to move into the engine bay.
Like an injector firing into the inlet manifold, pressure has to be higher the rail side than chamber.
mine used to run hot once i had the GRS and alloy rad put on. i did have a 82degree thermo too.
or anyone else that had no problems how was yours mounted, fans, etc?
again cheers for the ideas and we fitted the grs how the instructions said and the car just overheated at the sight of traffic but other than that couldnt fault it.i think a change of position could be in order if get another grs as we saw a few nice ones at donnington last week that had moved them lower down,and im quite good at overcoming head scratching moments after some of the stuff ive done with my bike ha ha,i will tell my brother what everyone has said and thanks again si
JK12
33
26-04-2021 12:09 PM
