engine noise help!!!!!
Old Aug 20, 2008 | 11:00 PM
smerth54's Avatar
smerth54
Exclamation engine noise help!!!!!
right this is doing my head in, the engine was supposed to have had a rebuild b4 i bought it and its tappinng,
ive changed the cam shaft and its still making the same sorta noise any ideas hears a video of the noise, help please
Old Aug 20, 2008 | 11:39 PM
LHD220Turbo's Avatar
LHD220Turbo
difficult to tell from the vid; my initial thought was top end, but on second hearing i'm not so sure
i assume its there from cold as well as warm?
never had one of those engines so not too familiar with them; what have you tried so far?
any tell tale signs of a worn bottom end?
Old Aug 21, 2008 | 09:06 AM
I'd go for rocker wear or tappet wear, not jacking up properly.
Old Aug 21, 2008 | 09:08 AM
Jim Galbally's Avatar
Jim Galbally
did you change just the cam on its own?
Old Aug 21, 2008 | 09:13 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
i can not tell by looking at the video wot engine it is i take it is a cvh??? try changing the lifters as well as the cam
Old Aug 21, 2008 | 09:19 AM
fish99's Avatar
fish99
CVH 1.6 Turbo...if its standard that is
Old Aug 21, 2008 | 09:28 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
CVH lifters are quite noisey in general anyways !!
Got no sound at work, but looks like a standard CVH rocker cover.
Are they new lifters wit the cam & are all the rockers tight ??
jb
Old Aug 21, 2008 | 09:29 AM
g1234's Avatar
g1234
that sounds worse on a vid to me on that sounds like bottom end nocking as well as tappets theres two tones of nocking one deep nocking and one rattly tapping
Old Aug 21, 2008 | 03:36 PM
smerth54's Avatar
smerth54
sorry yea its an rs turbo cvh engine i changed the cam shaft and the lifters? maybe i didnt do them u to the right setting whats the torque setting 4 the rocker arms?
Old Aug 21, 2008 | 04:11 PM
davidreader5's Avatar
davidreader5
What was the engine like before you changed the cam and lifters, what is the oil pressure with the engine hot, and cold, rocker arm nut 25-29nm, or 18-21,Ibft, did you bed the cam in with the lifters,, and is the cam timing correct as it sounds like a diesel, what make cam is it,
Regards Dave R.
Old Aug 21, 2008 | 05:51 PM
smerth54's Avatar
smerth54
Regards Dave R.
erm in what way? , dont know th oil pressure aint got a oil guage, i think the timing is correct but my mechanic m8 did it so duno, im no gd at timing really
Old Aug 21, 2008 | 05:57 PM
LHD220Turbo
cant your mechanic mate have a look at it for you?
Old Aug 21, 2008 | 06:13 PM
smerth54's Avatar
smerth54
yea but ive asked him and he doesnt really say much so cant b ared with him tbh, took me like nearly 2 months to get him to change my cam shaft and that so lol
Old Aug 21, 2008 | 06:16 PM
smerth54's Avatar
smerth54
i think ill torque up the rocker arms and check there right and see if it still persists but any other ideas would be grateful
Old Aug 21, 2008 | 06:34 PM
tonyrally's Avatar
tonyrally
passionford god
is it diesel lol....... no just kidding it sounds like little ends to me
Old Aug 21, 2008 | 11:53 PM
smerth54's Avatar
smerth54
haha yea i was thinking the same
Old Aug 22, 2008 | 07:16 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
To bed a cam in you have to run it @ like 2k for 10-15 mins.
How quickly does the oil light turn off when you start the engine ?? Both hot & cold, is it split second or is there a moment between the engine firing & the light extinguishing ??
jb
Old Aug 22, 2008 | 04:01 PM
smerth54's Avatar
smerth54
erm like a second or so not that long but not straight away
Old Aug 22, 2008 | 05:11 PM
AJ_ERST's Avatar
AJ_ERST
I had a knocking on my last engine, youd have sworn it was the cam, turned out to be the bottom end, confirmed this by takin a sparkplug out of each cylinder one at a time and firing it up, when I got to the dodgy cylinder the knocking was quieter due to less pressure on the bearing.... not the most accurate diagnosis but worked for me. have to agree with the other post, sounds like there are multiple knocks... or is someone at the door!
Old Aug 22, 2008 | 06:36 PM
smerth54's Avatar
smerth54
hmmm the engine was meant to have had a rebuild b4 i bought the car so it cant have been done well if im gettin problems already
Old Aug 22, 2008 | 06:57 PM
g1234's Avatar
g1234
all depends who rebuilt the engine and why it was rebuilt if it was rebuilt due to nocking before maybe not cleaned out properly and picked up a bit of crap again if i was closer id come and have a look
Old Aug 22, 2008 | 07:18 PM
jameswrx's Avatar
jameswrx
sounds like my old cossie when i timed it up wrong and the valves were hitting the pistons
Old Aug 23, 2008 | 01:04 AM
smerth54's Avatar
smerth54
spose that could be right, will ahve to take it to a garage and get it timed up see if that sorts it
Old Aug 24, 2008 | 02:08 PM
smerth54's Avatar
smerth54
right i tightened up the rocker arms to the torque setting but still no change, but i found out 2day that my mate got me a normal 1.6 cam instead of the rs turbo one now would this make it knock?
Old Aug 26, 2008 | 04:07 PM
smerth54's Avatar
smerth54
bump
Old Aug 26, 2008 | 04:08 PM
Jim Galbally
no it wont make it knock
iirc the std cams are the same anyway
Old Aug 26, 2008 | 04:18 PM
phil_rs's Avatar
phil_rs
yam yammer
Sounds bottom end related to me bud
Old Aug 26, 2008 | 04:57 PM
escorted series 1's Avatar
escorted series 1
And there was me thinking my cvh was noisey.Put it in a garage mate
Old Aug 26, 2008 | 11:17 PM
smerth54's Avatar
smerth54
gr8 thats all i need how much does a bottom end normally cost then?
Old Aug 27, 2008 | 06:31 PM
smerth54's Avatar
smerth54
up
Old Aug 27, 2008 | 06:56 PM
LHD220Turbo
do it yourself, they are easy by all accounts
Old Aug 27, 2008 | 07:07 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
bottom end mate.take crank out,get it reground and brand new matched shells 4 it.sorted!
Old Aug 27, 2008 | 11:28 PM
smerth54's Avatar
smerth54
oh rite didn't realize it was that simple. is there any where around hertfordshire that would reground the crank then? or would a zvh conversion be cheaper?
Old Aug 28, 2008 | 05:19 PM
rickbartlett
G911 TTA
i paid 120quid 4 a crank grind and new shells.must be somewhere in ur area that work in engineering engine work mate.place i use is in daventry northamptonshire. carcom engineering
Old Aug 28, 2008 | 05:24 PM
rst in breaking's Avatar
rst in breaking
how does the noise sound when reving the engine?
Old Aug 28, 2008 | 05:58 PM
IANS2RST's Avatar
IANS2RST
sounds more like the little end bearings which unfortunately means new pistons
Old Aug 28, 2008 | 06:33 PM
smerth54's Avatar
smerth54
its gets a tiny it louder but not 2 loud and but it doesnt start as soon as i turn the engine on it takes a little time and you can only hear it when the revs drop quite low like 1000 revs cos it normally sits on 1500revs
malkiemac3579
Jul 14, 2017 12:10 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
