Ford Mondeo 2004 Towbar
Resident Wrestling Legend
ebay flog quite a few
then get the actuall proper wiring plug in harness for the car from sone of the big manufactueres for around £50, literaly plug and play with one or 2 holes to be made in the plastic under tray of the bumper for the wires and plate to go through and it's done
took me about 3 hours all in to bolt up and wire in
you only need 6 bolts, but make sure they come with the kit, they bolt into the holes in the chassis rails at the back
you just need to remove the rear bumper and some of the panels in the back to get everything where you can see it, plus you need to drop the exhaust o gain access to 2 of the bolt hole locations but if you have a degree of mechanical ability it's easy, you dno't even need a jack
ask away if you need any pointers
http://cgi.ebay.co.uk/FORD-MONDEO-ES...6.c0.m14.l1318
http://cgi.ebay.co.uk/FORD-MONDEO-WI...6.c0.m14.l1318
http://cgi.ebay.co.uk/FORD-MONDEO-TO...6.c0.m14.l1318
all theones shown there are different the one i've got as it's a much higher instal
but essentially it's the same designwise
the 2 long plates bolt to the chassis rails in the preholed sections
then you bolt the middle bit to these plates, then the towbar ball bit and wire up the electrics
removal of the bumper makes life much eaiser, but mine came from an estate to fit an estate so that might be why it's different in the looks department
borboyous
22-08-2015 11:17 AM
