cant remove my flywheel :(
no i cannot undo any of the 9 bolts holding the flywheel onto the crank
tappign them with a hammer is not possible due to the proximity of the bolts and the fact they are only 16mm
my usuall method is to use the teeth on the flywheel and my crowbar i jam it in between the teeth and the floor using the weight of the engine but its just not working with this badboy lol
A good trick i always use is to use a Battery clamp. Put a bolt through the centre and into one of your gearbox mounting holes, turn the clamp until it locks into the teath of the flywheel. You can then undo the flywheel bolts.
Matt.
Matt.
Testing the future
did this last week the easy way mate.
go out and buy one of those 12V hammer action wheel nut undoing jobs. put it on your battery and something inside spins up and suddenly whacks the bolt undone. do it 2 or 3 times on each bolt and they'll fly out.
excellent tools. will find a link in a sec to show you what i mean.
trust me, this is the best way if you don't have a proper air hammer or proper electric wazz gun.
using one of the bellhousing bolt holes (with no threads in it) slide a punch into it and use that as a leverage point to get you bar against the teeth of the flywheel if you get me....
i have found a mate with an air gun and another mate who runsa hire shop is letting me borrow a compressor so i will be trying to do it like that first
thansk for all your help
Ask your friend to take a spanner, grad one of the flywheel bolts with it and hold the spanner really tight.
Then you go sit in the drivers seat and turn the key
Testing the future
this is the ting i'm talking about. i paid 30 euro's for mine from pikey aldi, but got my brother one from demon tweeks that was a bit more than that (surprise)
http://www.demon-tweeks.co.uk/catalo...P079&pgrp=M005
http://www.classic-car-weekly.co.uk/...cgi?s=ac&o=696
to get to the flywheel the gearbox has to be removed so thus so does the starter lol
