Apexi avcr wiring to a ofab powered ka
hello has anybody ever wired in an apexi to an rs turbo managed car? i am wanting to fit one to my ka turbo and am not 100% where to connect to.
i have had a brief look at the wiring diagtram and this is what i have come up with
apexi
red wire - ignition power on ofab ecu pin1??
purple wire - rpm signal - tacho wire green on frst loom?
green wire - ground
black wire - ground these need to be connected to the same ground - pin 57 on ofab loom???
grey ire - throttle signal - pin 47 on ofab loom (brown/green wire)
white wire - speed signal - pin 4 on ofab loom (brown/white wire)
any help and advice would be helpful at this stage???
gary
apexi
green wire - ground
gary
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Gary - just as a quick heads up - make sure you put the 2 ground wires on about an inch apart and not together...
If you're still stuck for wiring pin outs - PM me on Monday, i'm sure i've got an OFAB list in my toolbox
