M7 bolts wanted,where from?
Looking for some M7 stainless cap head allen key bolts about 40mm long
Does anyone know where I can get some from?
Need about 50 or so
Need about 50 or so
Make you own from 8 or 10mm ones lathed down, tap and die set job done.
7mm will not be 0.7mm pitch, way too fine, most likely 1mm or 1.25/1.5.
I used some 4mm ones yesterday to secure my new TPS(Ł25 NEW) on my sapphy they were 0.7mm pitch as had to tap holes.
My oe tps had the bottom 30 odd degrees missing, and the off the shel chips overfuel so much I didn't even notice.
After a tiny bit of mapping on the new ecu it is transformed, not finished though.
ps if you still have a problem PM me, and I'll post you some
M7 Allen Head Bolts
If anyone is still looking for these I've found a website in Toronto that carries M7 x 20 , 30, 40, 50 from $4 to $6 each.
http://www.torontocycles.com/
WhoFan
WhoFan
M7 Stainless Cap Head
Group Components will get them for you if they have none in stock, otherwise http://www.a2stainless.co.uk/E-M7-x-...se_B217L5.aspx
Nothing 40mm though.
Steve
Steve
ebay is your friend... i just searched for M7 bolts and found about 10 adverts or so... edited to say theyre all hex and not cap heads!
Have a look on yell.com for fastener companies near to you, they'll probably stock them or get hold of them sharpish for you.
Lukesville
Vespa and lambrettas run with M7
http://cgi.ebay.co.uk/STAINLESS-STEE...4.c0.m14.l1262
JoeyBoyden
14
15-08-2015 09:51 PM
Gadget
Ford Escort RS Cosworth
14-08-2015 07:19 AM
Gadget
13-08-2015 08:19 PM
