The effect of Nitrous on spooling up a turbo
DEYTUKURJERBS
We know it does, but i've never seen a before and after comparison graph.
But heres one, so might be of interest...
"80bhp" jet, 3litre engine and GT42 turbo. (in think). Properly wakes it up though!
escort mk4 cossy 4x4
i use a 50 shot, probably = more like 70 in a turbo engine.
i wouldnt launch at 8k without the nos,literally had to bounce it off the limiter,with nos,about 6k ,reving to 7k and it just flys away.
DEYTUKURJERBS
More you use, the quicker it would be. But a massive sudden hit may not be so controlable, and sure would cost you more in gas.
Ive seen cars that take 30secs to spool up using transbrakes and stuff without nitrous spool up in under 5sec using gas.
DEYTUKURJERBS
Dodgy grip on the dyno id expect.
I saw a graph from a 200SX at ATP the other day where the lines did a fucking Loop The Loop, I shit you not! Ill find em.
Euan- Its nothing to do with anyone who sells Nitrous.
Here we go with the loop
I have seen slip on a dyno before, but nothing like that! Mind you - never seen that much power on a dyno up close.
Stunning how it affects the spool up - graphs make the car look like it would be a good deal more driveable (to the layman at least!)
JJ
DEYTUKURJERBS
Added the comedy loop the loop pic above!
Never seen that before either, dynos do funny things when there is traction probs.
Wiggly lines are common, a lot more realistic than the etch a sketch straight lines we keep seeing on PF, but a loop the loop is a new one on me!
Testing the future
Happily retired
Surely Nos is cheating so why are the moderators allowing this to be aired, its unfair showing people the benefits of Nitrous when you are not allowed to use it according to leading lights on here.
*** Sierra RS Custard ***
The wiggle is caused potentially by the increase in exhaust gas on the nitrous meaning the wastegate is working harder to try and control boost as it cant react quick enough would be my guess.
Thats obviously not the point of the discussion though, its about the spool up, and that does EXACTLY what I always experience on the gas.
Keep telling people that about my car, I get better response to the throttle and quicker boost build on T34/nitrous than you will on a small turbo escos.
If you use a massive turbo, and a shot of gas that cuts out at a bar of boost, it lasts for ages too, as it is only on for a second or two to spool it, then once its spooled even though the nitrous cuts off again, the turbo stays spooled at revs that it could never spool at normally.
Properly good shit, I cant work out why anyone would want to NOT have nitrous on the car, so at least they have the option of going quick if they want, its not like you have to use it, just gives you the option.
#1 in Spelling Club
I wouldn't mind betting that the NOS graph at the top is the same, it needs a better clutch or something like that.
Testing the future
i think that if it were the wastegate, the boost curve would have the same shape, and it doesn't
do we know what was being used to control the wastegate?
DEYTUKURJERBS
Here is a quote regardign the graph above, it was a 3litre and GT42, but there was more to it, read below...
I 'think' IIRC that is a very early graph of the 240z with a very lazy torque converter.
I have another graph somewhere where we had 160whp by 3800rpm with 8 psi boost then with a 75 shot we had 510whp by 3800rpm with 30psi boost.
Had alot of this strange smoke comming from the tyres on the rollers after that, never did work out why
But as you said, its not the point of this discussion, its only a little quirk of the setup used for whatever reason.
JK12
33
26-04-2021 12:09 PM
