General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
This should help, match them up exactly like this pic and you'll be fine, there is also a mark on the body of the dizzy (you'll have to remove the cap, you'll see a small notch which the rotor arm should face when at TDC.)
It has to be one of the easiest belts to do, if you can do any belts this is kids stuff, just be sure to turn the tensioner the correct way as the wrong way will work but can put the belt run awfully close to the stat housing, turning the other stops this.
There is no need mate. The pics above show clearly how to do it
it does but to do it properly without risk of ruining the belt you need to take the crankshaft pulley off,especially if fitting the mountune grp a belt! (that is the only belt i ever used)
since when you you need to take the crank pulley off to change the cambelt
you have not done one then?There is only a tiny gap to get the cambelt thru down the crank pulley end,i am not sure if the std thin one goes thru but the grp a one can get damaged.
yes i have doen them and so has mark with me watching and he never removed the crank pulley. Grp a cambelt whatever that bloody means. Not a lot probably
when i did my timing belt on my cossie i didnt know that you could feed the belt around the crank pulley. I had to take my radiator out and use a puller to remove the crank pulley. It was really tight.
Rich, as far as I was aware the crank has to come off to do the cam belt.
then i have no idea how i did mine after my cambelt snapped as i never took the crank pulley off. Mark never took it off either when he timed it all back up for me with new pulleys. I dont even own one of them crank pulley tools so there is now way i could have taken it off
i must be magical as i didnt remove mine and i got the belt on and timed up correctly. Just a shame about the bent valves that were caused when the previosu belt snapped
maybe they used your method of installation..lol i take you run a std belt then,i never felt confident due to the thickness compared to the mountune one which is also heat treated (std belt is obviously fine though!)
