Who is the LPG expert?
I know someone on here does LPG stuff
any way i need a connection for the tank side of my filler system it looks like a 10mm? reverse thread and obviously i need to connect an 8mm pipe to it can i get something local or will i need to get one from a lpg retailer?
I got a full kit of a car we broke but it had an external tank so found a spare wheel tank but i got nothing to connect the filler to the tank it looks like a 10mm left handed thread for the inlet??
Any ideas?
Any ideas?
well put it this way im sure its left thread as i went and bought a 10mm to 8mm connector today and it wont screw in so im assuming that as the other tank i have is left thread on the fill then this one is the same
I'm gonna go down to a local place that has brass fittings and see if i can match something to it if not i may have to get a new unit for the tank
Audio specialist
new style fillers are 10mm flexi pipe and the old ones were 8mm solid copper filler pipe, if you have the larger filler type then you will need to use the 10mm rubber flexi tube and that can only be used with the new style fillers which are a fast flow quick fill effort, i will have a look in the shed see i f i have a few 10mm flexi filler pipes, i f i have then you can glady have one as i got them for bugger all when the lpg company folded i worked for.
The standard filler is actually JIC but you run a adaptor on them if your using either 8mm copper pipe or flexi pipe.
You can't use the flexi pipe on some single hole tank multivalves as the adaptors required foul the tank.
Probably not a bad idea taking the nuts to someone as even if I see a pic I may not be able to tell what you need.
Right got the part i was missing and fitted the system to the car i can get it to rev and drive on the gas but it just wont tickover is there anything i can do or check?
Single point but not a problem now sussed it.
Held the car at 2000rpm running on gas and turned the screw on the side of the vapouriser (spelling) till the engine sounded happy and then let go of the throtle and it idles fine drive nice too. Well happy now
DavidK
27-09-2015 02:55 PM
