ABS
Old Jul 31, 2008 | 10:39 PM
Cossie Helen's Avatar
Cossie Helen
Default ABS
Had my new brakes fitted tonight
Now my ABS pump and light wont turn off and also get a funny feeling when you push down on the brake.
Any idea's ?
Old Jul 31, 2008 | 10:40 PM
The DIVA's Avatar
The DIVA
Sounds like there is still loads of air in the system,could try bleeding them again ?
Old Jul 31, 2008 | 10:44 PM
Cossie Helen
Ok, Will give that a go tomorrow night and see if it makes a difference.
Old Jul 31, 2008 | 10:45 PM
mechanic28's Avatar
mechanic28
did you bleed the system or just change the pads??
Old Jul 31, 2008 | 10:48 PM
vikingboy's Avatar
vikingboy
Originally Posted by Cossie Helen
...also get a funny feeling when you push down on the brake.
"funny feeling" LOL
birds for ya!
Old Jul 31, 2008 | 10:51 PM
Cossie Helen
Yes we did bleed the brakes
Edge - Piss off
Old Jul 31, 2008 | 10:52 PM
0sykes0's Avatar
0sykes0
Edge - Piss off
hahaha i was waiting for that
vikingboy's Avatar
vikingboy
ROTFL
Old Jul 31, 2008 | 10:54 PM
Jim Galbally's Avatar
Jim Galbally
sure you bled the rears right, theyre done "funny" on a cossie
Old Jul 31, 2008 | 10:56 PM
mechanic28's Avatar
mechanic28
how did you bleed the system?
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
To save everyone saying the same thing. I know hwo fitted these brakes and he is an ex cossie owner and ford trained mechanic. he knows how to fit brakes and bleed the cossie system. He fitted my ap's 5 months back with no dramas.
So its something else other than bleeding
Old Jul 31, 2008 | 10:58 PM
Cossie Helen
Thank you Rich !
All was done properly, i sat and watched I try not to get my hands dirty
Old Jul 31, 2008 | 11:00 PM
vikingboy's Avatar
vikingboy
it cant have been done proper cos the pedal feels "funny"
CossieRich's Avatar
CossieRich
your welcome Helen.
He doesnt mess up jobs
Old Jul 31, 2008 | 11:01 PM
mechanic28's Avatar
mechanic28
well prehaps the pads need to bed in ?
CossieRich's Avatar
CossieRich
it would have been done proper Ian. trust me when i say this.
there is osmething else wrong as the abs sensors sit in the hub which isnt touched when you put new discs and pads on
Old Jul 31, 2008 | 11:02 PM
CossieRich's Avatar
CossieRich
nope. The abs light should go out regardless espcially when stationary
Old Jul 31, 2008 | 11:04 PM
Jim Galbally
probably fucked the pump or similar. it happens sometimes.
get it off to somewhere with the proper ABS diagnostics stuff, will save you time and money rather than trying to sort it without the right equipment.
vikingboy's Avatar
vikingboy
well, me not knowing much about cars, I'd say if my brakes worked fine before someone did some work on them and then they felt "funny" then 'something' cant have been done right......surely he tested them after fitting them and would have noticed something was "funny" when he road tested it?
or its a 1 in a million coincidence.....
make sure you let us know whats wrong when you find out though....and dont drive it fast until you find out!
Old Jul 31, 2008 | 11:08 PM
vikingboy's Avatar
vikingboy
arent they on a diagonal split? FR/RL, FL, RR?
Old Jul 31, 2008 | 11:09 PM
dojj's Avatar
dojj
Resident Wrestling Legend
it'll either be them not being bled properly, if there is an air lock in the system and it's found it's way to the valve block things do go decidedly pear shaped
the resivous cap not being put back on properly
or the pads and discs not beinbg bedded in yet giving you a spongey pedal
but my money is on the cap not being on
Old Jul 31, 2008 | 11:11 PM
dojj's Avatar
dojj
Originally Posted by MAD YUM
We only needed to bleed the front ones
So just jack it up and bleed the passenger side 1st
Take it l wont need to bother with the rear
the rears are bled "funny" with the ignition on and pegal pressed a tad
the fornts are just as per normal
easiest to cvheck the cap first as if there isn't enough fluid in the resivour then he lgihts will stay on and the pump will keep on pumping
Jim Galbally
dojj, thatll only light up the ABS light tho not the master brake light surely?
Old Jul 31, 2008 | 11:13 PM
Cossie Helen
Car is going nowhere, thats me not taking the Cossie to Ford Fair. Oh well would rather have it sorted for Nat Day as on track.
vikingboy's Avatar
vikingboy
Seconded....be great if it was that. Nice cheap fix....
Old Jul 31, 2008 | 11:14 PM
xr4x4rs's Avatar
xr4x4rs
in what way does the oedal feel funny when you press the brakes?
Old Jul 31, 2008 | 11:17 PM
Cossie Helen
The light was NOT on when i left the garage or when i was driving home.
Old Jul 31, 2008 | 11:18 PM
vikingboy's Avatar
vikingboy
sounds like you've lost fluid to me....
Old Jul 31, 2008 | 11:19 PM
vikingboy's Avatar
vikingboy
bump
CossieRich's Avatar
CossieRich
Right, so its not the cap is off, its not a bleeding issue, its not the brakes have been fitted incorrectly.
Old Jul 31, 2008 | 11:20 PM
dojj's Avatar
dojj
2 more things to check then
is there any fluid on the floor where the car is parked from possibly a leaky from the brakes?
is there enough fluid in the resivour?
then off to get teh abs put oto a computer to find out what the problem is, although the pump might calm down if it's cool
Old Jul 31, 2008 | 11:21 PM
Cossie Helen
enough fluid in there, none on the floor
vikingboy's Avatar
vikingboy
I dont think you can diagnose that Rich....
Im putting odds on the cap not being on or a leaky valve that was over or under tightened
Old Jul 31, 2008 | 11:32 PM
CossieRich's Avatar
CossieRich
Ian,
if the light was not on when they left the garage then th every much doubt the cap was off. What valve? it was a disc, pad and caliper change. There has to be something else. Sensor or wiring is my guess
Old Jul 31, 2008 | 11:45 PM
xr4x4rs's Avatar
xr4x4rs
need to know what the pedal feels like as this can say a lot
Old Aug 1, 2008 | 12:19 AM
xr4x4rs's Avatar
xr4x4rs
like its constantly pumping?
is the brake pedal rock solid?
if so then its the abs kicking in and the its been overbleed by the sounds of it
Old Aug 1, 2008 | 07:30 AM
CossieRich's Avatar
CossieRich
all a load of nonsense then Dave. Bet you had the right humplast night as well, swearing and blowing steam out of your ears
