opening a new window on vista
every thime i click on a link to open a new window, the window is small, as in its 'resored down', how can i change it
Never gonna give you up!
VW 08 is right but if that doesn't work then try this.
Right click just below the address bar *within a grey area* and select menu bar then you'll see the menu bar which says File, View, Edit etc. Then use File and Exit on the window size you want it to remember.
HTH
Tim
HTH
Tim
it only works for me if you manually enlarge it too full screen, dont use the button to the left of the 'x', drag the window to top left corner, then use the size thing in bottom right to stretch it out, then when does close it.
also make sure this is the only window open when you do it.
i have done this a few times now, held down shift whilst closing after both expanding by dragging the screen bigger, and after restoring it using the top right button.
still opens links in a smaller window
make sure its the only window open
ie. if its a problem for firefox, close all firefoxes, then open a new one, resize, close it and then open again.
JAmes.
JAmes.
its fine when clicking on internet explorer on the desktop, opens full size. Its only when i open a link on an existing page. even if i close all windows and then maximise the small one, and hold shift whilst closing, it still does it!
chowfornow
14
05-01-2019 09:01 PM
