Rev counter mod
Rev counter mod
Info please.
does anyone have a pic of details how to mod the rev counter
on a saff after a coil pack con?
is a pectel con if that makes any diffence.
cheers nik
cheers nik
Basically, if you have a wasted spark driver board, then i will of course send you my instructions, but if you are on P8 and have had it enabled in teh chip then half speed is correct and you will have to either run it off some diodes on the coil and hope it works, or fit another tach. Whoever sold you the P8 chip would have explained this normally though of course...
i got a super sexy stack tacho in mine to sort this problem. just be carefull if you are buying 2nd hand as some of the older ones have no options so you cant adjust them.
SMILER258
28-09-2015 09:04 AM
