Fully floating con rods and gudgeon pins....
the gudgeon pins are held in with a small wire circlip.
How do you install the circlip??
Is there a special tool required?
The clips are far to strong to compress by hand or with pin-nosed pliers.
Thanks for any help.
Matt.
Matt.
Originally Posted by boost mad
this may sound silly but have u tried circlip pliers. they work in reverse so that if u squeeze the handle rather than closing the end it opens it! just a thought
My fully floating pistons had a circlip without eyelets though.
They are not a standard type circlip with the holes for pliers.
They are a wire circlip, basically just a bit of round wire.
Its a really strong spring wire and really hard to bend, so i think you must have to use a special tool.
Matt.
This is a pic of one
Matt.
![](https://img.photobucket.com/albums/v48/zvhturbo/circlip/piston-circlip.jpg)
Always make sure you install them in a room with a clean floor because you will ping at least one across the room while trying to get them in and they are a bugger to find afterwards!
I usually order a couple of spare circlips with every set of pistons if i can.
I gathered that would be the case so ordered 10.
How do you go about installing them??
I usually uses the 'brute force' method with these on 2 stroke engines
but they can sometimes be put in by hans slightly wonky, then using a flat, sized piece of bar pushed into the pistons hole into the reatining groove.
