peugot 206 rear hight adjust ment
Old 13-07-2008, 09:34 PM
abdr500
abdr500's Avatar
Default peugot 206 rear hight adjust ment
peugot 206 55 plate how does the rear adjust for hight any one no
Old 13-07-2008, 09:35 PM
rapidcossie
rapidcossie's Avatar
rear what?
Old 13-07-2008, 09:40 PM
RWD Pete
RWD Pete's Avatar
suspension? torsion bar get the wd40 out lol
Old 13-07-2008, 09:42 PM
abdr500
abdr500's Avatar
so how is it done lol
Old 13-07-2008, 09:44 PM
RWD Pete
RWD Pete's Avatar
oh god last one i did were a 306 pretty sure theres a torques bolt in the rear axle once removed the torsion bar has to be knocked out of the splines then pushed back in to suit height which is a trial and error job, not a two minute job
Old 13-07-2008, 09:45 PM
rapidcossie
The bolt is usually SOLID! best to spray WD on its for a good few days then have a go.
Old 13-07-2008, 09:46 PM
RWD Pete
RWD Pete's Avatar
what years the car
Old 13-07-2008, 09:50 PM
abdr500
abdr500's Avatar
55 plate and realy need a littel more info on how its done that way i can understand what needs to be done befor i do the job
Old 13-07-2008, 09:51 PM
RWD Pete
RWD Pete's Avatar
shouldnt be too tight on a 55 plate mate
Old 13-07-2008, 10:04 PM
mcst
mcst's Avatar
You'll need a slide hammer to extract the torsion bar. You need to disconnect the shocks. Measure each side from the centre of the hub to top of the arch before you do anything though!
The torsion bar is splined on one end so once its disconnected you move the beam up to the desired position measuring as above on both sides to ensure they match. Relocate the torsion bar in position and refitting is the reverse of removal as haynes tell you!
I'll be honest and i've never done one but i'm going to attempt it on my 205 when time permits. I've got this from the haynes-manual-of-making-it-look-easy and (you may laugh) an episode of wheeler dealers. Its the theory anway.......
Old 13-07-2008, 10:47 PM
JHS
JHS's Avatar
Dont count on that, had someone lower my 206 when it was only 6 months old. They were stuck pretty hard
Old 13-07-2008, 10:58 PM
abdr500
abdr500's Avatar
what make are your wheels how much are they do the come in et15 and 18"
Old 13-07-2008, 11:02 PM
JHS
JHS's Avatar
My wheels are Cromodora magnesium centrelock 8,25x19"s You dont even want to know the price, and even if you did it wont help much because they stopped making them years ago
Old 13-07-2008, 11:19 PM
vinnyvangough
vinnyvangough's Avatar
Torsion bar definate, age of the car dont matter in the slightest, one of my mates has done shit loads and some go easy some dont. Most dont!!!! Fom what i remember on the 206's 2 splines lowered is the best option as 3 looks uber cool and euro but function is a problem.
jessie_rs
62
06-08-2019 09:27 PM
155lee
06-09-2016 11:10 AM
yatta
21-05-2016 10:31 PM
cossirob
03-09-2015 09:17 PM
Quick Reply: peugot 206 rear hight adjust ment
