2WD head on 4WD block will this work ok??
Mate of mine just snaped a camshaft on is 4wd cos and fooked the head right up.
He can get hold of a 2wd head will this be ok on a 4wd block what do you need to change etc..
RS in the blood
i have a 2wd head on my 4x4 bottom end, the oil feed to the turbo will have to come out of where the oil pressure switch is (mail oil gallery) and the water temp sender is on the turbo side on a 2wd head at the front, other than that it will go on with out a problem,
hope this helps u m8
Yep it will be fine mate, plenty of people (including myself on my old Saff) have done this, be aware though that it lowers the compression ratio somewhat, by how much depends on how much the head has been skimmed but on mine it dropped it to just above 7.7:1 (but mine had only ever had one light skim).
YEah of course it fine as most peeps put 200 blocks etc while still using 2wd head in there car including me. Though dont know if u need to alter anything as i didnt build MAD bid
lockie
31-07-2015 10:03 PM
