evo question/problem
Old Jul 13, 2008 | 10:10 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default evo question/problem
...my pals evo 4 has started to die in 5th gear only..........it looses power, the engine light comes on and then it goes onto 3 cylinders..........he thinks its the/a coil pack......what u think..????
Old Jul 13, 2008 | 04:56 PM
pete mcrash
....err............tumble weed
Old Jul 13, 2008 | 05:00 PM
jameswrx's Avatar
jameswrx
I think I've read his post on the MLR?
Is it the one where he's fitted a 7 gearbox etc?
as355f1's Avatar
as355f1
plugs mate
Old Jul 13, 2008 | 05:12 PM
pete mcrash
....yes fella.........he's having a lot of bad luck with it at the mo..........
pete mcrash
Originally Posted by as355f1
plugs mate
..........why only in 5th
Old Jul 13, 2008 | 05:16 PM
as355f1's Avatar
as355f1
cos thats when its at max boost and its prob blowing the spark out, had the same prob on a cosworth, for the sake of £30 its worth a try, if it was coil pack it would do it all the time
Old Jul 13, 2008 | 05:34 PM
pete mcrash
..........know what ur saying but it isn't a on boost problem.......
Old Jul 13, 2008 | 07:36 PM
as355f1's Avatar
as355f1
so at zero boost say cruising along in 5th at 40mph the car will start to missfire but drop it to 4th and it clears ?
Old Jul 14, 2008 | 04:51 PM
pete mcrash
drive it through the gears its fine untill u put it into 5th.........it looses power then the engine light comes on and it starts missing/3pots..............if u take it out off 5th before the engine light comes on it sorts itself out.......but once the light is on it will miss fire in all gears...............he's changed the coil and had 3 sets of plugs in
Old Jul 14, 2008 | 04:52 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Import or UK car?
Old Jul 14, 2008 | 04:53 PM
pete mcrash
Originally Posted by Chip
Import or UK car?
...import evo 4.........................but its been in the country for years
Old Jul 14, 2008 | 04:54 PM
Chip's Avatar
Chip
Was this problem there before changin the box, or only since?
Old Jul 14, 2008 | 04:55 PM
turbo_3dr_tommy's Avatar
turbo_3dr_tommy
Import or UK car?
all 4's are import chip mate
Old Jul 14, 2008 | 04:56 PM
Chip's Avatar
Chip
Good point!
Old Jul 14, 2008 | 05:01 PM
pete mcrash
......after....but..........he's had nowt but shit luck with it of late.......went bang.......engine rebuild....oil pump fail...engine rebuild
........rear diff fucked.......gearbox fucked.....turbo fucked.........now this strange pallavour...............(should av bought a ford.....)
Old Jul 14, 2008 | 05:11 PM
jameswrx's Avatar
jameswrx
I'm wondering if it's something to do with the gearbox sensor and possibly a faulty or bodged de-limiter or something?
He hasn't changed the ecu as well has he?
Old Jul 14, 2008 | 05:14 PM
pete mcrash
....dont think so......but it's nothing to do with speed either............it's as soon as u put it into 5th.........could be a gearbox type problem..........he's gone from a 4 to a 7 box
Old Jul 15, 2008 | 04:25 PM
pete mcrash
is that it then..?????............or can one of u genius's help...???...........UPPP
Old Jul 15, 2008 | 08:34 PM
as355f1's Avatar
as355f1
without seeing it dude it could be a million things, what has the diagnostics said or have you not had it plugged in ?
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
YODI
Aug 30, 2015 01:12 PM
TomPengelly
13
Aug 22, 2015 06:38 PM
