does someone know this relay?
Old Nov 1, 2004 | 01:14 PM
cossiemen's Avatar
cossiemen
Whassup
Default does someone know this relay?
on a 2wd saphh. cossie
it's sitting behind the dashboard instruments, it's an 'Hella' item and has the numbers 30, 85, 86, 87 on it. There are two red wires connected onto coming straight from the battery and there's a black and green wire going to somewhere.
don't know where it's for and if it's realy needed so i hope someone can sort this out for me
cheeRS for any help
Old Nov 1, 2004 | 01:20 PM
AlexF's Avatar
AlexF
30, 85, 86, 87 are the pin numbers for the relay... its a std for all relays!
pins 85 and 86 supply the 12V feed to the relay coil
pin 30 is the relay switch COMMON and is usually connected through a fuse to 12v
87 is the switched output
Old Nov 1, 2004 | 01:56 PM
cossiemen's Avatar
cossiemen
Whassup
so it can be used for several things i suppose??
when i started rebuilding my saphh i thought it was used for the alarm fitted to my car, i've trown the alarm out (it was crap) but now i'm not sure if it's realy has something to do with the alarm.
so if anyone seen this relay on his/hers saphh just tell me where it's needed for.
Old Nov 1, 2004 | 02:04 PM
foreigneRS's Avatar
foreigneRS
Testing the future
that is not a genuine ford relay, and they are not genuine wires.
looks like it's something that someone has added and made a mess
there is a relay behind there for the heated front screen, you could see if they've replaced the wiring for that.
Old Nov 1, 2004 | 02:08 PM
cossiemen's Avatar
cossiemen
Whassup
ohh dear
deffo sounds not good
now i have to sort everything out
and the electrical department is my weakest link
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
tib2220
Sep 14, 2015 12:33 PM
