Do escos front brakes fit..
A mk5 escort sport?? ive got rs2000 set up on at the moment but want a big brake conversion,just wondering if escos brakes fit as standard so its easier to find a bigger set up???
The quick answer is "yes"
You will need some 10mm spacers for the calipers and thats about it![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Or you could do what i done and fit V6 Mundeo Brakes which are the same and just need the Caliper Carrier ground down a tad as they are 280's as well![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Cheaper i found because they are NOT Cosworth
While you are doing the Fronts, you might as well do the backs as well and fit an RS2K rear Beam. With the fronts and back both done, i found it totaly Transformed the car and you will benifit from a handbrake that actualy works
Cheers guys ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Yellowsierra ive already got a full rs2k set up,fronts and rear beam just want a set of bigger brakes for the front as they look shite behind 18" rondells
