are bd16 cams noisey?
just got mine fired up for the first time, and it has a noise at idle, sounds top end,
seems to be at idle, and on the pick up when reving...
only ran it for a min, so may even be tappets
its fine if i hold it at 1500rpm
Norris Motorsport
No they're not normally noisey. You do need to run them in at 2000 rpm for 20 minutes after which the tappets are normally quiet.
One problem you may have is if you have not ensured your valve springs can cope with the extra lift? If this is the case the tappets will remain noisey.
Cossiemodo
DANISH cosworth abuser
it´s just the tappets, and if you run iskys you might have to modify the seats, if you run the standard springs with inserts, you shouldent have a problem.
Run mine on std with inserts and bd16+ cam with no problems what so ever.
Leave it @ 2k for some time, and they should be ok again, otherwise you have to get some new in
Mc5506
05-10-2015 09:57 PM
