Help 5" Turbo hose
02-07-2008, 04:03 PM
Happily retired
Help 5" Turbo hose
Any ideas where I can get a 90 deg reducer 5" (GT42) down to 4" ( K&N). The normal places dont do one.
Thanks Rod
02-07-2008, 04:07 PM
MAD Carbon Cossie
Have you tried Roose Rod ?
If he doesn't do one, he'll prob be able to knock ya one up no probs ! Either that or sleeve it @ the ally trumpet end ??
jb
Lukesville
Is this a silicone reducer or a alloy one Rod
02-07-2008, 04:13 PM
Caraholic
Quote:
Originally Posted by
MadRod
Thanks Rod
If that is the case, then I think the only way you will do this is to use some high temp flexible ducting which is available in 127mm diameter. However, it will mean a new trumpet being machined up to match.
02-07-2008, 04:21 PM
Lukesville
Rod when Nick comes up at the weekend to Marks look at his alloy turbo tube on the Capri...
Our good friend Clive made that one so im sure he could do the same for yours and it will be made to suit your application perfectly.
02-07-2008, 05:19 PM
1st to 200 without NOS
MadRod
Thanks Rod
Why don't you cut the 4" pipe out of the trumpet and get a 5" one welded in place? No reducer then!!
02-07-2008, 09:43 PM
Happily retired
martin-reyland
Yes I can but then I need a 5" 90 & I cant find one of those either.
02-07-2008, 09:47 PM
get Mark to phone Alan at AVA and he will sort you out Rod.
It was speciallymade but not sure what company did it.
02-07-2008, 09:52 PM
Happily retired
rapidcossie
Can I pinch that one
. Will phone tomorrow.
Thanks
02-07-2008, 09:56 PM
MadRod
Thanks
It took 4 weeks to come I know that much Rod
and that was rush job(quality is only 99%)
Might be able to sort you a loan for a few days if its holding you back from the event?
02-07-2008, 09:58 PM
In fact, scratch that Rod...
its been cut down now to fit the air filter set up on the scoob( panel sits in the scoop) so its more like a 45 deg bend now.
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
kevin36
02-09-2015 06:24 PM
jaimesdna
25-08-2015 06:59 AM
