044 pump flow
Old Jul 1, 2008 | 07:22 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default 044 pump flow
how much fuel do they flow in litres?
Old Jul 1, 2008 | 07:25 PM
Miller 3's Avatar
Miller 3
I have been told the the 044 has a very similar flow rate to that of a normal cossie fuel pump ? How true this is .. is another matter mate ?
Old Jul 1, 2008 | 07:33 PM
JTECH James
Passion for Fords!
mm, kust looking at filter options, 300lph enough?
Old Jul 1, 2008 | 07:44 PM
Miller 3's Avatar
Miller 3
Im just running a standard fuel filter' as far as im aware this will be ok ?
Old Jul 1, 2008 | 07:49 PM
JTECH James
Passion for Fords!
yeah i think so, im after one with -8 fittings,
but not sure what flow i need....
Old Jul 1, 2008 | 07:52 PM
Miller 3's Avatar
Miller 3
Quote
The popular Bosch Motorsports "044" fuel pump is used by Japanese, European & Australian tuner shops, JGTC cars, Touring cars, almost all WRC cars, and many more. Quite possibly, the most popular aftermarket fuel pump. Capable of providing 300 LPH free flow and 200 LPH at 5 bar (or 72.5 psi) for up to 685 BHP. In comparison, the Walbro GSS341 255 "high pressure" fuel pump can support 390 BHP Note: Values calculated at 12V, 3 bar (43.5 psi) base fuel pressure, 2 bar (29 psi) boost pressure, 1:1 fuel pressure regulator ratio. These are inline fuel pumps, we recommend they be installed between the factory (or another aftermarket) in-tank fuel pump, and the fuel rail. These may be installed in the fuel tank, but some custom fabrication will usually be required. In addition, feeding these inline pumps with another pump (in series), will boost the output of the Bosch 044 fuel pump even higher.
Old Jul 1, 2008 | 07:54 PM
dave cos4x4's Avatar
dave cos4x4
i don't know but i'm having one on mine aswell as the other bosch pump,swirl pot aswell etc....
Old Jul 1, 2008 | 08:02 PM
JTECH James
Passion for Fords!
ithanks guys!
all sorted now
Old Jul 1, 2008 | 08:46 PM
Fiecos Dan's Avatar
Fiecos Dan
Bosch rate them at 3.7 ltr/min @ 73psi @ 13.5 volts, = 222 ltr/hour
but 044's i've tested
at 13.0 - 13.4 volts at pump, @ 73 psi = 4.1-4.6 ltr/min = 246-276 ltr/hour
A bullet filter is fine, but best to put post pump, then it wont restrict the flow at all unless blocked.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 29, 2015 11:27 AM
