Best boost controller
I curently have one of Stu's single air injectors that worked well on my old engine , but i dont like the idea of the injectors bleed on and fail closed.
What boost controllers work well on cosworths, can any have two preset boost levels.
Neil,
Im running a Greddy Profec B Spec 2 Controller, which is one of the more basic controllers.
You can save a low & high boost setting and make a number of adjustments. Also has high boost warning and saved peak boost.
http://www.thor-racing.co.uk/GReddy_..._-GDY__PF2.asp
Tony i was wondering that, if you could 'T' in and use the air injector as a bleed off . Would this give as good control, atleast that way if it failed it should just run the max boost set on the actuator.
Car is in for mapping just now, map and cam timing have been done on low boost so now time to do the boost side of things.
Super Moderator
you can also have 3-12 position boost control
the theory behind bleed on is very valid however when you drive the two types you can't tell ,I have mapped them this way before for other concerned customers who have had air injector failure and consequential damage.
What turbo are you using jap boost controllers don't control big turbo's and big boost very well ,unlike the pectel air to air system and it's copies
Super Moderator
injector long livity is imo affected by the boost control pressure pick up point best after the intercooler not from the turbo,temps leaving the turbo compressor can exceed 200 degrees C
If you have the mapping software no reason why I can't map it to bleed off
there is nothing wrong with a p8 it is a serious ecu
Is an air injector with the boost control pot something that can be fitted "stand alone" from the rest of the ECU/wiring?
I have always wanted a good high boost/low boost switch on my car.
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
