Rear mounted turbo?
yes they work, lots of yank turbo conversions are like this as it's faiyl easy installation, just not idea for power/driveability
Testing the future
looks like a reasonable install, but i would've used an aluminium pipe from compressor outlet with some fins on it as it would cool the charge better than the steel one and be lighter
*** Sierra RS Custard ***
Agreed that heat on that setup could be an issue.
The other thing to remember is that if you have any holes in your exhaust they will bloke like a bastard as you end up with pressure the WHOLE way down not just in the manifold like on a conventional setup.
If you can manage those two things though, no reason it wont work well enough for lowish boost though.
Easy install too of course if you just run a remote oil reservoir and cooler and pump, as its all self contained (bit like the water cooling for the turbo on my nova which runs its own system.
On this side of the pond STS is big into these kits. It's not rear mounted, it's 'remote' mounted.
http://www.ststurbo.com/
I guess what ever works.
Here's Stav's post.
https://passionford.com/forum/general-car-related-discussion/238127-interesting-205gti-sprint-car-with-rear-remote-mounted-turbo.html
And a E60 M5 with remote turbos.
![](http://images.paultan.org/uploads/2007/02/bmw_m5_twin_turbo_7.jpg)
Testing the future
i would have thought that off boost torque would be reduced due to the VE being reduced to having to breath through that length of pipe, but it's probably not significantly worse than breathing through an intercooler and a compressor anyway.
the air filter will need changing/cleaning more regularly, but it may well be sited in a high pressure area under there due to the rear valance. still warm and dirty though - the front of the car is the best place for the air intake, or out the top somewhere
DEYTUKURJERBS
If you want pure performance then only a fool would mount it anywhere but close to the engine.
BUT for various other reasons it does make sense to go there, and certainly works.
TBH id say its hard/impossible for any of us to honestly talk about it, as we've never done it, and theory is massivley different to reality in most things with cars.
It's something I have in mind for a 351W I have lying around though to be honest. Just for interests and rooms sake as much as anything.
Id love to know the real difference in lag/threshold with identical turbos though, from what ive read the difference is fair, basically say if it was a GT35, a .63 housing but rear mounted drives like a 1.05 housing in the usual place.
There are cars in the US running 7second 1/4's with rear mount setups.
Nobody is saying they are ideal, or perfect. Why did they do it at all ??
Emissions laws in some parts of the US are mental, and you cannot touch any of the emissions control equipment.
So a front mounted turbo would be very difficult.
Fit it after all the emissions control....and suddenly you can have a turbocharger setup, that is quite legal ( oddly, the ecu tuning is ok as far as legality goes as far as I know )
The pipe run to the front is not enough to cool the air. That is just nonsense. It may cool a tiny tiny amount, but thats it.
Simple answer is that these kits are cheap, relatively easy to install, and give usable power gains.
So why not ? Most of the US cars are auto, as they dont seem to be able to change gears manually, so lag really isnt an issue.
Put your foot down, the car kicks down gears, revs its nuts off, and you have boost.
if the length of the pipe affects spool up time is there no way you could have either a twin setup or even a supercharger for the low down revs then the rear mounted one could be as big as you wanted because you have no space issues?? or have i completely missed the point??
Testing the future
probably more significant is the energy in the exhaust gas that will be reduced by the temperature drop over the long run between exhaust valve and turbine - lag it or ceramic coat it and it may help. as stated earlier though, you will have a lot higher pressure in the downpipe and exhaust system than normal, so it has to be well joined together with no leaks
i thought by changing the exhuast manifold for a turbo car you could change the engine characteristics, ie the further away the more tourque but less throttle response and vice versa??
Resident Wrestling Legend
if the turbo is close to the engine, don't you have to make sure you have even length pipes to it to stop it from haing a negative effect?
with the turbo at the far end, you will have a much better constant flow of gasses to spin it up yes?
the other thing is that when you rev an engine, it takes a matter of portions of a second for the exhaust gas coming out the tail pipe to start spewing out, so i don't think you've have much of a problem spinning a turbo up that was rear mounted
plus there wouldn't be as much heat in the engine bay to melt stuff
plus there wouldn't be as much heat in the engine bay to melt stuff![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Absolutely not. Pretty much anything that directs the gases into the turbo, will work. It doesnt need to be fancy, smooth, or anything really. Of course free flowing helps, but it is not essential.
If anything, its sharp pulses that really kick the turbine into action as opposed to smooth flow from each cylinder.
Lack of heat in the engine bay is one advantage too...plus its also very discreet for those that dont want to advertise the fact it is turbocharged..
pa_sjo.
These were originally designed as a cheap upgrade, for strict emissions control cars. They are not mainly on drag cars. They were designed primarily for road cars. But as many are autos, as I said earlier, lag is less of an issue, as the auto box helps that out. But quite a people use them for drag cars too now.
Matt Baxter
16-09-2015 08:30 PM
track.focus'd
12-08-2015 05:53 PM
xr4x4rs
06-08-2015 09:03 PM
advantage, convential, conventional, housing, installation, m5, mount, mounted, nova, oil, pump, rear, remote, sab, turbo
