sterio remote wire help needed
hello sterio question the remote wire on a kenwood what colour is it normallly and does it have live or earth going through it was told this wire switch on the amp but i put my tester to it it doesnt have any power going through it o does the amp send the power to it and then the sterio does its thing please adise me on this if you can
should give live..
make sure you havent picked up on the electric aerial feed, as when the cd player is working the aerial goes down...only goes live on tuner setting
one is blue, the other blue and white
so what colour should the wire be should be live when sterio is on i tried to test it with a tester to see but nothing showws power sterio works
Remote wire is blue, and goes POSITIVE when stereo switched on, a lot also have a seperate AERIAL feed that does the same, marked POWER ANT.
I have never seen a Kenwood yet that loses it's remote or aerial feed when switched to CD either.
If you phone(my mate) BOB on 01728 746100 he is the main repair centre for all of the UK for Kenwood, and does pretty much all other makes as well, the company name is FULLERS, been doing it since before the ark was made, also carry all sapres etc, and sell graded units.
If it's a cheaper Kenwood may not have a separate remote (blue as previously said), had this problem fitting the first one of em at work. If it doesn't use the power aerial feed brown iirc.
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
