rs500 t4 on standard head has anyone done it ?
24-06-2008, 04:33 PM
just wondered what boost a standard port head would take with a proper t4 before it started surging ? has anyone tried it ?
24-06-2008, 04:57 PM
it was ok on mine at 28 lbs.
24-06-2008, 05:43 PM
PassionFords Creator
Normally start to surge a buit around 25psi.
24-06-2008, 06:39 PM
ford did it at the factory!
24-06-2008, 06:49 PM
Quote:
Originally Posted by
Stu @ M Developments
Normally start to surge a bit around 25psi.
Would a largened penny washer help with that at all Stu? Or am I confused, and getting my terminology the wrong way round?
24-06-2008, 06:50 PM
dave cos4x4
& went like stink when Karl mapped it
24-06-2008, 06:59 PM
Cake lover!
Mine had just cleaned up ports and that went alright at 28-29psi boost.
24-06-2008, 08:36 PM
mine was standard and held 30psi,ported wastegate though
25-06-2008, 08:31 AM
im curious as id like to be making 2.2 bar from 4k without surge. my head has only had lite porting and a polish and am wondering if it could be my inlet manifold causing the surge between 4 - 5k rpm. if i can be certain itl cure it i wana put on small turbo escos inlet and remap with a bd15 inl cam and be on full boost straight away.
how certain can i be its my 4x4 inlet causing the surge and not the head ?
25-06-2008, 08:59 AM
mine boosts at 24 psi on std head
25-06-2008, 09:12 AM
Did Someone Mention TUV
would using a GT30 have the same problem? Does having a different cam such as BD14 get round the problem somewhat?
25-06-2008, 09:39 AM
Mine Gt3076, have anti surge kompr. house
25-06-2008, 09:47 AM
grcossie
is that also know as a ported shroud?
25-06-2008, 09:52 AM
25-06-2008, 10:20 AM
Mines at 25psi at the moment and will be 30psi soon on a totally standard engine
25-06-2008, 11:50 AM
what injectors are you using gary and what ecu
26-06-2008, 03:52 AM
Still on p8 mate, and im using siemans injectors.
26-06-2008, 07:12 AM
milkman
nice
what kind of figures are you making Gary?
26-06-2008, 07:24 AM
Passionford Thread Killer
SmudgerByName
52
28-07-2016 06:14 PM
3i Jim
20-11-2015 05:12 AM
wheelwizardrefurbs
05-09-2015 10:52 AM
hopper350
04-09-2015 12:53 AM
mint_s2
02-09-2015 08:58 AM
