Improving fuel consumption - Live map or closed loop?
ps: jim i REALLY live in central london and travel AGAINST the traffic outwards hence i get travel for shorter times
going the otherway then its a 45 mins drive to work driving up muswell hill with the city boys
not necessarily, it may have been disabled if it has been 'tuned'
although that means that it came from the factory with it
for years, 4x4 cossies that came from the factory with lambda sensors and closed loop fuelling were modified by 'tuners' who ought to know better and the closed loop function was cut out as run programs from other chips were copied across.
still to this day you get people selling chips based on rally car maps that do not have the closed loop fuelling part of the software written in
PassionFords Creator
so 90% chance that if that guy has a lamda sensor its got closed loop from the factory, i could have also said cat but alot of people remove cats claiming its for performance but in reality its also down to money when the cat fails
another way is to check the fueling,,, if its .9% CO then theres a good chance its got closed loop...... if its running 3 to 10% co then theres a good chance its either been taken out the chip/got a faulty lambda/ missing the cat or just dont have closed loop
hope that explains things a little better
JK12
33
Apr 26, 2021 12:09 PM
