Stack Gauges
Old Jun 22, 2008 | 09:02 PM
lozi's Avatar
lozi
My Cossie Ate My Money
Default Stack Gauges
i have fitted a stack boost gauge to my saph, the stepper one, but i cannot workout where to wire the live to
it needs to be switchable but live while the engine is cranking which means the sterio is no good
cheers
Old Jun 22, 2008 | 09:16 PM
trevCOSS's Avatar
trevCOSS
why does it need to be live whilst the engine is cranking also you could use the live going to the rear of the clocks
Old Jun 22, 2008 | 09:18 PM
lozi's Avatar
lozi
when you switch the gauge on it calibrates so a break in power means it re calibrates and by the time it has caught up the engine has started and its giving a false reading
Old Jun 22, 2008 | 09:21 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
theres loads of ign live while crank feeds in the rear of the fuse box, probe one out
Old Jun 22, 2008 | 09:25 PM
trevCOSS's Avatar
trevCOSS
I have a number of stack gauges and im not sure thats quite true, my rev counter and fuel gauge both become interupted when starting the car and it has no effect on there operation
Old Jun 22, 2008 | 09:28 PM
lozi's Avatar
lozi
well it does definatly have an effect on my boost gauge, its still re calibrating when the engine has started so its not going to read correct, it gives me 17psi on boost when it should give me 10 lol
Old Jun 22, 2008 | 09:40 PM
Jasesapphy's Avatar
Jasesapphy
think your elec window black/yellow is uniterrupted
Old Jun 22, 2008 | 09:41 PM
rapidcossie's Avatar
rapidcossie
my windows defo stop briefly as you turn the key.
Old Jun 22, 2008 | 09:45 PM
Tev's Avatar
Tev
cheers
How bout the stereo feed?
Old Jun 22, 2008 | 09:47 PM
lozi's Avatar
lozi
like i said the sterio turns out while the engine is turning over so the sterio is no good
i had it wired to the sterio and it was way over reading
Old Jun 22, 2008 | 09:52 PM
rapidcossie
what about feed to the digi clock?
sure its always on.
Old Jun 22, 2008 | 10:00 PM
lozi's Avatar
lozi
sure its always on.
nice ill try that next
Old Jun 26, 2008 | 12:24 PM
kjc300's Avatar
kjc300
I think my apexi 2.5 bar gauge is doing this too, as I can see what you mean. If it calibrates to zero when switched on, and the engine is obviously on vacuum at the time (cranking) it's going to over read by the vacuum amount??
I have a boost controller with boost display (profec B spec II) and it disagrees with the apexi by half a bar under at 2 bar!!
I have a mechanical gauge coming so will be able to check for sure shortly!!
Old Jul 12, 2008 | 09:03 AM
kjc300's Avatar
kjc300
Have you sorted this yet mate?
Just tried mine on the ecu feed pin 20 which comes direct from the battery through a relay switched by the ign.
STILL drops the power. Now I know the battery voltage is going to drop whatever whilst cranking, so I'm going to try straight to the battery and see if it still drops too much for the gauges on cranking.
only other thing it can be is a faulty map sensor on the gauge.
Old Jul 12, 2008 | 09:27 AM
kjc300's Avatar
kjc300
Right, I've just connected the gauges straight to the battery and then started the car and the voltage still drops too low for the gauges to stay on!!!
So unless it is the gauges map sensor faulty - I cant do anything about it!!
Although my old man has mentioned something about a ballast resistor??? Anyone know anything about them?
Old Jul 12, 2008 | 09:40 AM
rapidcossie
Some kind of resistor might just be the way as they hold voltage even tho they are being constantly suppied with it.
What do the stack instuctions say?
Old Jul 12, 2008 | 09:44 AM
kjc300's Avatar
kjc300
I don't know about the stack, but the apexi ones say "connect to ign live".
Old Jul 12, 2008 | 09:46 AM
rapidcossie
even if they are impossible on a car as like you said even the bat volyage itself drops too much
Old Jul 12, 2008 | 09:50 AM
JamesH's Avatar
JamesH
If it dont even work off the battery ( ) I'd want my money back
Old Jul 12, 2008 | 10:34 AM
kjc300's Avatar
kjc300
Well mine does now appear to be a faulty gauge or the map sensor for the gauge.
I connected the gauge up to a booster pack AND the car supply, started the engine and the gauge stayed on. I then disconnected the booster pack and went for a drive. The gauge is still over reading by at least 8 psi.
So mine is nothing to do with it calibrating whilst cranking.
I hope you sort your stack Lozi!!!
Old Jul 12, 2008 | 10:40 AM
trevCOSS's Avatar
trevCOSS
I honestly dont think that it needs a cranking live, mabe the stack gauge is also faulty?
Old Jul 12, 2008 | 10:45 AM
R5FORD's Avatar
R5FORD
maybe you should get defi gauges instead
Old Jul 12, 2008 | 10:53 AM
JamesH's Avatar
JamesH
I think the gauges are faulty guys
I had a faulty STACK gauge the other week
Old Jul 12, 2008 | 10:54 AM
JamesH's Avatar
JamesH
PS
Once its calibrated itself it should probably hold that calibration for say 30s without power, hence why cranking is not an issue (unless ya car don't start )
Old Jul 12, 2008 | 01:24 PM
kjc300's Avatar
kjc300
Maybe, at least he can send his back - my apexi is a bit old for that!! lol.
Old Jul 12, 2008 | 02:51 PM
lozi's Avatar
lozi
no definatly not, it even says in the instructions about it.
ill find the instructions
i still have not sorted it btw is there nobody about who has got a stack boost installed?
Old Jul 12, 2008 | 03:56 PM
trevCOSS's Avatar
trevCOSS
I have but its the non stepper one and its poo it flutters all over the shop, I was thinking of getting a stepper one tbh, I think I will wait and see how yours works out lol
Old Jul 12, 2008 | 04:02 PM
trevCOSS's Avatar
trevCOSS
I owe you an apology, you are indeed correct, here's what it says
Connect the red power wire to a switched +12 volt source that maintains power during engine cranking. Most vehicles break the electrical connection to accessories while the
engine is being started. If the boost gauge is connected to one of these circuits, the auto zero function will not work properly and inaccurate readings will result. To determine
whether a switched source maintains power during starting, look for electrical accessories in the vehicle that remain on while the engine is being started. Connect the red power
wire to the same circuit that powers one of these accessories. The connection can be tested by turning the key switch from off to on, the pointer will move backward to the stop
pin and then move to zero. Once the pointer has reached zero, start the engine. If the pointer reads vacuum without returning to the stop pin, a suitable connection has been
found. If the pointer moves to the stop pin and then reads vacuum, another power circuit must be found.
Power-Up
The pointer will move backward to the stop pin and then move to zero. This procedure is an auto-calibration function and is performed on every power-up. While this test is being
performed, the gauge may make a clicking sound. This is normal.
Electronic Boost/Vac gauges are equipped with an auto zero function used to compensate for operation at varying altitudes. This function takes a pressure reading during the time that the
key switch “flies through” from the ON position to the START position. The reading represents zero pressure and is used to set the zero point on the gauge each time the engine is started.
You can get a cranking live feed from the same place as the ecu
Old Jul 12, 2008 | 04:37 PM
JamesH's Avatar
JamesH
Well, that is quite shit. I was considering getting a stack boost gauge too!!
Old Jul 12, 2008 | 05:44 PM
trevCOSS's Avatar
trevCOSS
lol yes just have to make sure that as your driving up that mountain that you occasionally stop and turn the engine off and back on to re callibrate the boost gauge to your altitude. lol I may still get one.
Old Jul 12, 2008 | 05:49 PM
lozi's Avatar
lozi
i need to find somebody with a saph who has 1 of these gauges so i can wire same as them.
the gauge is just sat in the dash doing nothing but light up lol, wish id kept the old mocal gauge in
Old Jul 21, 2008 | 04:37 PM
lozi's Avatar
lozi
this is now sorted, i have wired it to a live on the light filment indicator unit and it works great now good gauge
wiring to electric windows work's as well
Old Jul 21, 2008 | 04:46 PM
trevCOSS's Avatar
trevCOSS
excellent, I may have to invest in one as my cappilary stack us completely poo, it vibrates round and is an eye sore unless its getting a few bar of boost at which point it stabalises.
Old Jul 21, 2008 | 04:48 PM
lozi's Avatar
lozi
i used to have a mocal capilary gauge and this gause is 100 times better, it moves so smooth and i think its slightly more accurate and less randomly all over the place lol
now i need to work out why the petrol light/picture of car on dash dont work, they work for about 1 minute once a month lol
Old Jul 21, 2008 | 05:06 PM
JamesH's Avatar
JamesH
Any chance of a pic to where you've wired it in mate?
Old Jul 21, 2008 | 05:26 PM
lozi's Avatar
lozi
dash is back together now mate, the yellow and black wire that goes into the window switches worked.
if you drop the bottom of the dash off drivers side there is a light bulp fail indicator unit in there i just tested each wire into it for power and found one
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Mc5506
Sep 29, 2015 09:06 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
