well, its been a long time coming...
Old 22-06-2008 | 06:13 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default well, its been a long time coming...
but finaly my car is almost ready to run.....
been a long trek since i decided to give it one more go,
a few odds to sort out, and fit the fuel cell, and she will be winging her way to stu for a live map
heres a few random pics i got today...hope you like
more pics in a mo
Old 22-06-2008 | 06:14 PM
J1mbo's Avatar
J1mbo
B1mbo
lookin good m8
Old 22-06-2008 | 06:15 PM
mechanic28's Avatar
mechanic28
looks brilliant fella!!!a credit to ya!
Old 22-06-2008 | 06:17 PM
Staffi's Avatar
Staffi
Looks superb mate, you've done her proud fella, looks quality under the hood too, that'll be a nice drive back from Stus James....
What box is in it now then?
JTECH James
Passion for Fords!
track slag
Old 22-06-2008 | 06:19 PM
rapidcossie's Avatar
rapidcossie
LOve the cam cover and pulleys!
LHD220Turbo's Avatar
LHD220Turbo
looking good James; love the rocker cover and cam pulleys
Old 22-06-2008 | 06:20 PM
JTECH James
Passion for Fords!
suspension hasnt settled down yet, as its been on axle stands for 6 months, first time on wheels today
Old 22-06-2008 | 06:21 PM
JTECH James
Passion for Fords!
i wanted to be a tad different from before, so chose matt black, the pulleys are 909 style quaife peg adjustable numbers
Old 22-06-2008 | 06:26 PM
dakar's Avatar
dakar
Looks awesome on those wheels mate
Tarren's Avatar
Tarren
Fair play fella looks a real nice one a credit to you
im sure msd will do there superb work
Well done!!
Old 22-06-2008 | 06:27 PM
col cos1's Avatar
col cos1
nice 1 mate,both of us running similer spec,will be good to compare graphs
mine is nearly there now
Old 22-06-2008 | 06:28 PM
JTECH James
Passion for Fords!
il post my full spec in a mo mate,
Old 22-06-2008 | 06:32 PM
KSA-Cossie's Avatar
KSA-Cossie
Thats stunning james,MSD will finish her off nicely pal.
Old 22-06-2008 | 06:33 PM
JTECH James
Passion for Fords!
here we go
this should be the final spec....
Ford sierra Cosworth
K535 XVS
Engine:
Re-bored 200 block
6 Long studs (new type)
Multi layer WRC head gasket
Cometic inlet manifold gasket
Cometic cam cover gasket
Genuine Swedish plenum
Billet fuel rail
Gas-flowed and port matched inlet manifold
7.2:1 low comp forged pistons with valve pockets
Polished crankshaft
Balanced con rods
ARP big end bolts
Lightened and balanced flywheel
Genuine high flow oil pump
Big wing sump (8 litre capacity)
BD16 inlet cam, BD14 exhaust cam
Quaife peg style 909 vernier pulleys
CNC Gas-flowed head(Rick Wood)
Double valve springs
Genuine INA hydraulic lifters
Modified breather system
Genuine Rs500 T4 turbo (water cooled,360deg bearing)
RS500 style intercooler
Turbo cooler
Oil cooler
2wd exhaust manifold
Bailey turbo damper
Bailey header tank
Bailey oil separator tank
Bailey twin piston DV
Samco hoses
Mongoose stainless exhaust system, modified front pipe
Poly exhaust mounts
Mikalor exhaust clamps
Custom engine bay wiring loom
Single Air injector
K+N cone style induction kit
Turbo oil pre filter
044 fuel pump
Alloy fuel cell in boot
Aeroquip fuel lines
Vibratech engine mounts
Siemens 83lb injectors
Coil pack conversion
Water injection
Live mapped by Motorsport Developments (closed loop)
Anti lag and Launch control
Estimated power, 500bhp
Transmission:
Mullit straight cut big tooth gearbox
Alcon 6 paddle clutch kit
ARP flywheel bolts
Front diff strengthening plate
Lengthened front driveshafts
Front diff cover bung
Gear change cradle poly bush kit
Fully synthetic 75/90 race spec gear oil
Suspension:
Gaz coil over kit
Solid alloy rear beam mounts
Full poly bush kit
Adjustable front track control arms
Compression struts
R+B rear shim kit
Front and rear strut braces
Brakes:
ABS removed
Rear bias valve (internally adjustable)
Synthetic fluid
Front:
6 pot calipers
350mmx32mm rotor and bell
Braided hoses
Hawk race spec pads
Rear:
Standard rebuilt calipers
300mmx20mm rotor and bell
Braided hoses
DS2500 pads
Wheels/Tyres:
8x18” Compomotive MO (anthracite)
Yokohama parada spec 2 tyres (215 35 18)
Interior:
Standard raven leather
Innovate wideband kit
Oil pressure gauge
Oil temp gauge
SECS monitor
Boost gauge
__________________
Old 22-06-2008 | 06:39 PM
JTECH James
Passion for Fords!
Old 22-06-2008 | 06:40 PM
LHD220Turbo
why the big writing? is it so it makes your spec looks longer?!
Old 22-06-2008 | 06:41 PM
JTECH James
Passion for Fords!
copy and pasted mate
Old 22-06-2008 | 06:44 PM
Munch's Avatar
Munch
Mr. Sparkle!
nice one mate!
take it she wont be ready for combe?
Old 22-06-2008 | 06:46 PM
JTECH James
Passion for Fords!
i dont think so, still got bits to do, and run in before its mapped,
im not booking its map untill it starts and is ok...
Old 22-06-2008 | 08:08 PM
JTECH James
Passion for Fords!
anyone got 2 manifold to trouser bolts? i need some!
Old 22-06-2008 | 08:26 PM
bigchez's Avatar
bigchez
That looks fantastic, and what a spec bet you can't wait till its all finished.
Old 22-06-2008 | 08:29 PM
JTECH James
Passion for Fords!
no,i cant wait now.....really missed driving her
Old 22-06-2008 | 08:43 PM
col cos1's Avatar
col cos1
ive always liked the look of your car mate,the front bumper espcially
Old 22-06-2008 | 08:48 PM
JTECH James
Passion for Fords!
both bumpers have damage at the mo, i hit a rabbit at 90, and the bottom bar of the bumper hit the intercooler( 5 inches away!)
so, over winter i will blow em over again....
Old 22-06-2008 | 08:49 PM
trevCOSS's Avatar
trevCOSS
looking good mate, some excellent progress, Look forward to seeing the car back on the road again.
Old 22-06-2008 | 08:54 PM
Miller 3's Avatar
Miller 3
Dude it looks lovely .. Not long now pal
Mine realy needs some coilovers as it is way too low .. and its only a -25 mm drop
Old 22-06-2008 | 08:57 PM
JTECH James
Passion for Fords!
cheers guys..
i think the engine bay looks really busy in the pics, but it doesnt in the flesh....weird
Old 22-06-2008 | 09:03 PM
moonstone_cossie's Avatar
moonstone_cossie
really looks mint! cant wait to see some finshed pics!
Old 22-06-2008 | 09:22 PM
Nash's Avatar
Nash
Cake lover!
Spot on mate, be really nice to see the car in the flesh again mate.
Old 22-06-2008 | 09:35 PM
Staffi's Avatar
Staffi
Great Spec that James, will be a blast to drive,,,,
Old 22-06-2008 | 09:36 PM
hai07222's Avatar
hai07222
Looks great!
Old 22-06-2008 | 09:40 PM
JTECH James
Passion for Fords!
i expect it will be a pig off boost,
just cranking it over, i can tell its got proper lumpy cams
Old 22-06-2008 | 09:42 PM
James's Avatar
James
whats the bonnet pins on the bumper for?
looks and sounds good though.
Old 22-06-2008 | 09:43 PM
Stu.H's Avatar
Stu.H
Looks good mate, dont forget to jubilee the turbo hose!
Old 22-06-2008 | 09:46 PM
JTECH James
Passion for Fords!
the bumpers are just shells, thats what holds them on,
i take them off to jack it up etc
Old 22-06-2008 | 09:47 PM
rssteve's Avatar
rssteve
to take the bumper off i guess?
too late.
JTECH James
Passion for Fords!
new hoses coming...that ones a tad small for my liking
Old 22-06-2008 | 09:48 PM
Staffi's Avatar
Staffi
Like that's gonna happen alot.........
Old 22-06-2008 | 09:50 PM
JTECH James
Passion for Fords!
yeah,true...
i need to get a 40psi boost gauge!
Quick Reply: well, its been a long time coming...
