NO FANS :(
NO FANS :(
hmm wonder if someone can help I don't have my fans kicking in when it should and the switch to turn them on/off doesn't It has been working fine until I just took it out for a little run.
I've checked the fuse (I think it's number 22 in the fuse box?) and all seems good, now is there a relay under the passanger footwell that has anything to do with it? Also there is a red ended lead loose on the passengers side of the radiator now I am not sure if this needs to be pluged in or not as I can't find anywhere to plug it in and I presume it's part of the old Aircon unit (it looks like a red plug end with a male end and a plastic female end on it).....
any help would be most welcome
dave cos4x4, it was burnt before but can see the connectors and all was working ok will have a proper look after
may need one of DazC's wireling thingies
