were can i get a std new clutch cover?
Caraholic
You can get the standard clutch cover direct from Ford. However, I wouldn't recommend it, as they have switch to using a cheap version that is not much good for anything beyond standard power . It will work, but it won't last very long before it needs replacing (a few thousand miles of hard use).
Roosie, the Full Alcon kit (cover & plate) was lighter than the std clutch that came out when I originally switched over to paddle - just fit a new cable at the same time (you look like you need one ayway, lol).
mike ive jut text you about a alcon clutch if u had one in stock?
