General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
its on my new cossie but not connected to anything it has to outlets on top and 1 right at the bottom bear mount. what goes on them 2 outlets and what goes on the bottom one,seems different to my old cossie one
Ive just seen this after posting my thread about the breather and catch tank. So my cam cover will have a hole drilled into it somewhere?
if its all tubro cover im not sure.. but on any other there is a whole on the underside at the back right.. all you have to drill is drill that whole out.
You need a heat shiedl Roosie, and a new clutch cable!!
The two pipes as said are for the rocker breather and the block breather, there should be another which vents to atmosphere and one drain back to block, although drain back may not be in this desingn, but I think I can just see another stub on the piccie on the underside ?
Sump return is under the turbo, not sure wot you mean about the small one under the inlet, if its still got the standard setup you need to throw that away just leaving the kidney box and then run a pipe from that to the catch tank, Matt Lewis sells the fitting kit for these.
