any mobile welders near Wood Green ?
put up a steel palisade fence this weekend at a school and everything went well ............... til well put the 2 single gates up , the fook lugs that the gates sit on had been put on the wrong side ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
couldnt believe it . before people say its not a case of turning it round etc , it basically has been made to face the opposite way to the fence !
anyway , i need a mobile welder to come to wood green in london , cut 4 lugs of and 2 keeps , and then welder them back on the opposite post . im desperate to get it done and its for cash !!!!
my usually welders have gone on holiday for 2 weeks . perfect timing !
and one want to do it give us a bell . im on 07796 072993 Kris !
the lugs that need cutting off are about 10mm by 60mm thickness and the keep is only 5mm by 20mm i guess.
the lugs are basically a flat bit of metal that is 10mm by 60mm and it is 75mm long with a 12mm pin on the top of it , so its the 10mm by 60mm end that need welding to the opposite post which is 4inch box section which is about 4mm thick .
