COSWORTH 4x4 transmission fluids ????
Hi i was recommended by a ford mechanic to get the castrol stuff for the diffs and gearbox,went to halfrauds to look it up on their chart.transfer box is atf got the same info from halfrauds also.
I'm interested in this too. Spoke to Opie last week and wasn't convinced when they said to use the same fluid for everything. The manual gives different specs for them. Wasn't sure if the guy was flannelling me TBH ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Neil.
Neil.
Passion for Fords!
its perfect....ford oil spec is for std cars...not tuned ones producing lots of heat....
ive done 50k miles on fully synthetic 75\90 ,and its spot on.
bara, who builds the mullit box told me to never use anything else in them...theres hundreds of us using it....
its one of those once you use it, you think why havent i done this earlier![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
an example, front diff oil, normally when drained is black, burnt, stinks....weve all seen it!
with fully synthetic 75\90 in it, after 50k miles its still clean, not burnt, and smells fresh as the day i put it in!
![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
Front diff needs bottom plate removed to change oil think rear diff has to have back plate removed. think i'll try 75/90 oil as well.
2Evos & 1 Escort Van :-)
with fully synthetic 75\90 in it, after 50k miles its still clean, not burnt, and smells fresh as the day i put it in!![ban-split](https://passionford.com/forum/images/smilies/ban-split.gif)
how does this oil effect gear change when cold as i think it may be thicker than original ford oil and does it really make that much difference. only problem i will have is my gbox will fuck up before i get real benefit from the oil as will have around 475 horses
