whats needed on a 30k service on a focus 2000?
just sold our focus to my good friend, now it does need a service so i said id pay for it as its a friend and i didnt realise its due!
ford focus 1.6 automatic, year 2000.
oil
oil filter
pollen filter
air filter
spark plugs
fuel filter?
grease up all hinges
fill relevent fluids
anything else needed thats very important that ive missed? i fitted new brakes about a year ago.
oil
oil filter
pollen filter
air filter
spark plugs
fuel filter?
1 Post
25K service:
Service Schedule - Focus 1999 [ZETEC-E/AUTO] - 2 Years (25000 ml)
Driving Vehicle into Workshop
Instrument gauges, warning/control lights and horn Check operation
Washers, wipers Check operation/adjust, if necessary
Inside Vehicle
Exterior and respective control lights; instrument cluster illumination Check operation/condition
Handbrake Check operation/adjust, if necessary
Seat belts, buckles and stalks Check operation/condition
Outside Vehicle
Door check straps + Check operation/grease (steel check straps only)
Hood latch/safety catch & hinges + Check operation/grease
Under Hood
Wiring, pipes, hoses, oil and fuel feed lines Check for routing, damage, chafing and leaks
Coolant Check anti-freeze concentration: °C
Coolant expansion tank, power steering fluid, washer reservoirs and battery Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is required to investigate and rectify
Battery terminals Clean, if necessary/grease
Automatic transmission Check/top up fluid (must be warm, at specified temperature) - CD4E
Odour filter / Odour filter plus Renew - if applicable
Pollen filter Renew pollen filter with odour filter
Under Vehicle
Engine Drain oil and renew oil filter
Steering, suspension linkage, ball joints, driveshaft joints and gaiters Check for damage, wear, security and rubber deterioration
Engine, transmission, rear axle, transfer box Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines, exhaust Check for routing, damage, chafing and leaks
Underbody + Check condition of PVC coating
Tyres Check wear and condition, especially at tyre wall, note tread depth RF mm, LF mm, LR mm, RR mm
Brake system + Disc brakes: With wheels off, check brake pads and discs for wear. Check rear brake linings for wear (using drum brake inspection hole). (More often under severe duty conditions)
Outside Vehicle
Engine Refill engine oil
Brake fluid Check level - in the case of abnormal fluid loss only, a separate order is required to investigate and rectify
Tyres Adjust pressure
Spare wheel Adjust pressure, check wear - condition (note tread depth) mm
Luggage compartment lamp + Check operation - if applicable
Wheel nuts Tighten to correct torque and check for correct type. Check for rim damage
Wheel covers Check for damages, especially at retainer system
Service reminder sticker Affix to driver side B pillar
Extended Period Maintenance
Brake system Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning Every 3 years - Check temperture at the evaporator outlet tube. Check air conditioning lines for damage and leaks (LTS 34 619 1) (TSB 67/2002)
Cooling system Every 4 years - Check/clean pressure cap, renew if there is seal deterioration
Cooling system Every 10 years - Orange/pink coloured coolant. Drain, flush and refill with purple Super Plus (LTS 24 122 4)
Cooling system Every 10 years - Drain, flush and refill with purple Super Plus(LTS 24 122 4)
Camshaft drive belt Every 100 000 miles/10 years - Renew - (Zetec with auto-tensioner) (LTS 21 304 9)
Auxiliary drive belts Every 100 000 miles / 10 years - Renew front belt (LTS 21 567 5)
Visual Body & Paint Check Every 12 or 24 months depending on vehicle type and build year/registration date. Carry out during operations marked (+) above - see detailed Check Sheet - if applicable (LTS 54 555 1 +)
+ Visual body and paint check should be carried out during these operations on vehicles built from 03/2002 onwards - see detailed Check Sheet if applicable.
Separate labour charge dependant on market regulations.
Back
©Copyright, Ford Motor Company 1994 - 2008 | Privacy Policy
Inside Vehicle
Outside Vehicle
Under Hood
Under Vehicle
Outside Vehicle
Back
1 Post
Service Schedule - Focus 1999 [ZETEC-E/AUTO] - 3 Years (37500 ml)
Inside Vehicle
Outside Vehicle
Under Hood
Spark plugs Renew
Induction air filter Renew (more often in polluted conditions)
Under Vehicle
Fuel filter Renew
Brake system + With wheels/drums off, check brake pads, discs, linings for wear and check brake cylinders and drums for condition; check rubber components for deterioration (on vehicles with ABS, refer to TSB 81/2002)
Outside Vehicle
Back
Inside Vehicle
Outside Vehicle
Under Hood
Spark plugs Renew
Under Vehicle
Fuel filter Renew
Outside Vehicle
Back
Jack and the Beanstalk
09-08-2015 07:03 PM
