Sorted now.
Old Jun 3, 2008 | 05:59 AM
KSA-Cossie's Avatar
KSA-Cossie
Default Sorted now.
When driven a few miles from cold and the secs monitor hits 69-70 degrees,if at idle i get a burst of grey/black light smoke from the exhaust,just changed from silkolene pro s 10/50 to millers 10/60 would that be anything to do with it ? Any ideas welcome troops.
Doesn't smoke under boost conditions and has only done it twice .
Old Jun 3, 2008 | 07:51 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
No idea, but why have you changed oil?
Old Jun 3, 2008 | 07:55 AM
RWD Pete's Avatar
RWD Pete
can you smell fuel?
Old Jun 3, 2008 | 08:04 AM
SS1's Avatar
SS1
i ask that too
Old Jun 3, 2008 | 08:13 AM
JamesH's Avatar
JamesH
I found Silkolene gives lower oil pressure compared with Mobil1, possibly a reason for the change?
Or he's just tight
I read somewhere Kev that old age in the owner can cause this
I'd check plugs and if they are ok then I'd wait until it does it again/gets worse really...
Old Jun 3, 2008 | 08:44 AM
SS1's Avatar
SS1
mine hits 91 before the fans cut in
Old Jun 3, 2008 | 09:18 AM
SS1's Avatar
SS1
degrees,
what your secs monitor errors set at via engine temps
Old Jun 3, 2008 | 02:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Couldn't get silkolene at the time.
Originally Posted by RWD Pete
can you smell fuel?
Does smell when cold but not really when warm.
Or he's just tight
You might just be right jimbo.
degrees,
Not sure what you mean pal ?
Might just change back to silkolene as it was good as gold before that.
Old Jun 3, 2008 | 02:38 PM
CossieRich's Avatar
CossieRich
What does oil pressure have to do with it. Changing to silkolene does seem to give a lower reading on the oil pressure gauge, but that doesnt tell you how good it is at protecting your engine
Old Jun 3, 2008 | 02:51 PM
KSA-Cossie's Avatar
KSA-Cossie
Just to say it's a 2-3 second burst no longer
Old Jun 3, 2008 | 03:58 PM
KSA-Cossie's Avatar
KSA-Cossie
Fuck me it was only the escos heat shield burning on the exhaust must have been moved when i got my afr gauge fitted and the wind blowing the smoke under the car and me thinking it was from the exhaust.
Old Jun 3, 2008 | 04:14 PM
Jim Galbally's Avatar
Jim Galbally
SECS monitor reading like that means one of 3 things
1) faulty secs monitor
2) faulty wiring
3) faulty Coolant Sensor
Old Jun 3, 2008 | 04:28 PM
KSA-Cossie's Avatar
KSA-Cossie
Was a hot day jim so got up to temp quickly.
Old Jun 3, 2008 | 04:32 PM
Jim Galbally
sorry thought you meant it was giving bullshit readings
Old Jun 3, 2008 | 04:42 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
worth checking you havnt melted the rubber bush in steering cloumn if the heat shields caused an issue
Old Jun 3, 2008 | 07:58 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
phew!!
lol tho
Old Jun 3, 2008 | 08:06 PM
JamesH's Avatar
JamesH
Kev, did you go to spec savers in between seeing the problem, and finding the cause
Seriously though, glad its all sorted mate
Old Jun 4, 2008 | 05:59 AM
KSA-Cossie's Avatar
KSA-Cossie
Jimbo it was typical cossie paranoia
Old Jun 4, 2008 | 10:28 AM
JamesH's Avatar
JamesH
We all get it mate!!
You hear a knock and think "What the fuck was that "
Old Jun 4, 2008 | 10:49 AM
BIG WULL's Avatar
BIG WULL
Fae the Dale
Thank fook!! I thought it was just me with the paranoia
Old Jun 4, 2008 | 11:02 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Try driving a cossie after you have had TWO go on fire! Thats fuckng paranoia! Any steam, fog, dust and im crapping it
boeb
Jan 9, 2020 05:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
