Briggs & Stratton Engine Help????
Old May 30, 2008 | 11:57 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Default Briggs & Stratton Engine Help????
Hi i have a husquavana rider 13
And it konked out on me mid cut!
Ive cleanen and checked the plug, and there is a strong spark.
fuel is getting to where it should
all the saftey cut outs for seat and blades are working
oil level is spot on, (it cuts the engine if its to low)
battery it holding about 12.2V, and starter it working fine.
im at a lost end here, as i just cant work out why its not firing. its been the 1st time in 2 weeks that it hasnt been raining and as u can imagine it desperatly needs a cut.
anyone familar with the engines? its a 12.5 hp briggs and stratton 2001 model. id really apreciate some help.
Old May 30, 2008 | 12:02 PM
joffy's Avatar
joffy
SLOW LEARNER
if its a briggs engine ther will be a small black wire on the back of the engine, diconnect this and try it, if it works then one of the safety switches is faulty, try removing the plug and turning the engine over for about 15-20 seconds then putting it back and re trying?? if not id try changing the plug even if you clean it some show a fault within weeks!! an RJ19LM or B2LM plug is suitable,
Old May 30, 2008 | 12:10 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
ok thanks, ill try the black wire.
yes have tried reomving and turning over with no avail.
yeh was gna change the plug as well, only a few quid, worth a shot.
i got 2 acres to cut
will try wire and new plug and let you know. cheers matey.
Old May 30, 2008 | 12:13 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Check the air filter, if this is covered in oil / carbon, your head gasket has gone. Just had to replace mine - exact same engine.
Old May 30, 2008 | 12:14 PM
joffy's Avatar
joffy
SLOW LEARNER
if not PM me and il see what i can do,
joffy's Avatar
joffy
SLOW LEARNER
Where You Get Your Parts From Mike??
Old May 30, 2008 | 12:15 PM
Franco's Avatar
Franco
Fucking hell, how big is your garden!
Old May 30, 2008 | 12:16 PM
Mike Rainbird
Caraholic
A local company to me - "Matt's Mowers" .
Old May 30, 2008 | 12:19 PM
Mike Rainbird
Caraholic
Too big to use a self propelled It used to take me nearly 2 hours to cut the lawn with the little Honda, it now takes 45 minutes with the ride-on. However, the R&B Motorsport sticker has improved things .
Old May 30, 2008 | 12:28 PM
Franco's Avatar
Franco
I can see the spec list now:
Scs built & mapped
balanced bottom end
Comps in gold!
Old May 30, 2008 | 12:40 PM
joffy's Avatar
joffy
SLOW LEARNER
dont joke, i work for a company called GDC, we built a ride on we were going to race. 22hp as standard, skimmed head, lightened flywheel, racing exhaust, removed the governer, was stripped of most of it weight, was quite nippy when it was finished, all painted up in black and silver McLaren Mercedes F1 colours!!
Old May 30, 2008 | 12:41 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
have you checked the valves the valves were stuck on mine where is leaded petrol when you mower still needs it.
I have 32 acres to cut but only bother mowing the 2 round the house
Old May 30, 2008 | 01:05 PM
foreigneRS's Avatar
foreigneRS
Testing the future
some of you rich cunts with land need to get some cows or sheep - sod cutting that much grass
Old May 30, 2008 | 01:08 PM
Diamonds.'s Avatar
Diamonds.
i worked 9yrs in a mower place...fucking things
try making sure all the microswitches are connected ie the grassbox on if it has one, maybe one under the seat. if there not pushed down then it wont work either.
also how long has the fuel been sitting in there? and was it fresh fuel from pump to jerry can? or was it fuel thats sat in the jerry can for weeks/months?
Old May 30, 2008 | 01:35 PM
Turbosystems
Super Moderator
how much do you think grass costs per acre, fook all unless it has palnning permission for a house or better still a tesco
Old May 30, 2008 | 01:37 PM
Turbosystems
Super Moderator
shall we discuss our ride on mowers ,I have 2 the alco one i have is the dogs it even has 4 wheel steering I haven't chipped it yet .do you think martoon does a set of comp mo's for it roflol
Old May 30, 2008 | 01:59 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
its a bio chip, so no box to worry about. imagine a compost heap with 2 acres of cut grass each week sod that
machine is great, for me as the chassis articulates, not all flat land.
these things are about Ł4000k new, so i really cant afford a new one.
fuel is fresh, as said its used every week. gets through nearly a 5ltr jerry can each week so its not in there long enough to cause an issue!
i tried the black wire to cancel out the saftey circuit.
after leaving it for an hour it fired for about 3seconds?
but not wont fire again. i have a new plug so will try this now.
as for head gasket, yeh i suppose it could be. i did notice a small amount of oil/fuel on back axle which has come from engine?
how much was your gasket?
Old May 30, 2008 | 02:04 PM
joffy's Avatar
joffy
SLOW LEARNER
try the plug first, does it pop or bang when you turn it over?? on the engine there will be a model type and code number stamped into the casing, if youve got them i can find out the part number and price for the gasket for ya
Old May 30, 2008 | 02:06 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
this machine is quick, think it does about 15mph. and does dounuts on its "own circle".
also its fun as you can get pissed up on a sunday afternoon and go for it. its takes about 2 hours, and i always try to shave of a few mins. got it down to 1 hour 47 before now! and that is going some.
you have to do handbrake turns, and ive even had it on 2 wheels before. tho the center articulated chassis folded up on my, it was carnage. my mates found it very funny but it bloddy hurt
Old May 30, 2008 | 02:13 PM
Mike Rainbird
Caraholic
Glad I'm not the only childish one, you can do wheelies on mine, by reversing fast and then shoving it into forward .
Old May 30, 2008 | 02:17 PM
joffy's Avatar
joffy
SLOW LEARNER
its people like you two make my job a fuckin nightmare lol
Old May 30, 2008 | 02:22 PM
Turbosystems
Super Moderator
we have taken the cutters of in the past and raced my two mowers round the fields for about 5 minutes once.
get a life mike roflol
did you think you were driving your mower when you went over the roundabout
Old May 30, 2008 | 02:23 PM
joffy's Avatar
joffy
SLOW LEARNER
lmfao
Old May 30, 2008 | 02:25 PM
Turbosystems
Super Moderator
if only cosworth made mower engines
Old May 30, 2008 | 02:32 PM
Diamonds.'s Avatar
Diamonds.
if the oil has been changed regular and always on the level pretty much rule out scored bore...say that though it wants to start when it cooled down could mean its a problem there :S
if you got spark its not the electronic unit.
tbh i doubt the headgasket has gone on it.
the crank (shaft from engine out) isnt bent is it?
have you tried starting it with out the filter on? try that.
if not one of the first things i used to do is clean the carb out with an airline or a hard blow just make sure you keep your finer over the middle hole as some carbs lose the little gasket with a hard blow....and you wont find it...trust me them carbs are so small a little bit of shit in it and they piss you around
Old May 30, 2008 | 02:51 PM
Turbosystems
Super Moderator
perhaps you have got the firing order wrong on your single cylinder engine roflol
Old May 30, 2008 | 03:23 PM
Andreas's Avatar
Andreas
Mike, do you run it with some sort of collector to get the cut grass up and if so is like a normal mover where you have to empty it every 60ft?
We got a large garden too and I rather spend my time elsewhere than behind an old mover.
Old May 30, 2008 | 03:32 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
exactly it cost the same as an average saff cos so i expect to have some fun on it!!
i rebuild the carb a month or two back, as it was hunting like mad, looked like a learned driver kangarrooing along the grass. but to be honest im 99.9% certain its not a fuel issue, thers pleany coming through and it showed no signs of fuel starvation!
Anyway put the new plug in with no luck. so i had a closer look around the head gasket.
if you look closley to the left of the exhaust manifold is very oily?
took of the subframe to get to the head bolts, not 3 of them covered in crap
took of head, its definatly been blowing around the exhaust area.
so question is is this the cause? its defiantly blown as you can see half the block surface is dirty.
would this really just cause it to cut out and then not start at all?
anyway engine is 12.5 briggs
model 286707
type 1206-E1
code 0205 12ZE
gna get a quote on gasket from "earnest does" but thay aint normally cheap.
will my head need skiming
Old May 30, 2008 | 03:43 PM
Diamonds.'s Avatar
Diamonds.
put ya fingers in the bore is it scored at all?
pull it over make the piston come back even with the block and wiggle it see if you get much play?
pull it over and see if the valves are sticking?
just scrap of gently the sticky gasket and get a new one. about Ł8-Ł12 from that then it could be a factor yes. i never used to get many gaskets go tbh. and ive serviced thousand of them fuckers when was it serviced last i used to get customers that self serviced them and the head bolts werent dont up tight and that gives the problem too.
oil on 3 of them bolts and in your exhaust could be due to the ride-on hase been tipped slightly on its side cleaning underneath or something or over filled but more the 1st bit. dont worry will just burn off (you will get smoke just let it burn and make sure level is ok)
is the filter oily? if yes wash out with fairly liquid or clean with petrol and blow with air line.
and no dont worry about skimming
Old May 30, 2008 | 05:05 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
i was joking on the skimming btw
well just shot of to braintree (good excuse to take the cossie for a blast, some sexy blonde in a bmw 3.0l msport baited me aswell, she had a roling start on the roundabout so didnt put her to shame untill 4th gear. next roundabout a mile away i got a nice wave of appreciation, she would have got it aswell)
anyway got a head gasket for Ł6.16+VAT
will fit tommrow.
have left head in degreaser bath tonight.
piston is tight (i reckon) as that blonde bird in the BM and the bore is silky smooth like her arse. valves open/close as they should.
so really all it can be is the gasket? anyway will report back tommrow
it has regular oil changes.
Old May 30, 2008 | 05:12 PM
Diamonds.'s Avatar
Diamonds.
hopefully fella yeah.
anyway more on this Dorris
Old May 30, 2008 | 05:18 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
needs longstudding, and a wrc mower gasket....
mike, our john deere does wheelies to
Old May 30, 2008 | 05:26 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
you know the sort, husband is probably an ugly bastard but earns a nice wage.
shes well kept. medium long blonde hair, pretty face. prob about 30 ish
driving a silver 2 year old BMW convertible 3.0 m sport.
Old Jun 1, 2008 | 08:43 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Well it works
polished head
Group A head Gasket
polished valves and piston top
Twin exhausts
bit of tuning
light weight racing rear tub removed to expose blueprinted engine
Thanks for all your help, it runs like a dream again, (ps 2 of the pics maby be fake)
Old Jun 1, 2008 | 09:56 AM
Turbosystems
Super Moderator
is that the briggs and statton yb they always had head gasket problems roflol
Old Jun 1, 2008 | 11:04 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
dont laugh its chipped
sadly its only rear wheel drive, the 4x4 model is anothet Ł1500 extra
Old Jun 1, 2008 | 12:36 PM
Diamonds.'s Avatar
Diamonds.
FPMSL turbo'd ride-on that would be fucking funny just come on to boost as you turn the corner and straight through someones back fence
glad its wroking fine
Old Jun 1, 2008 | 03:24 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
cheers for the help.
i aint got no fences tho a turbo'd line 1/2 a mile into the field would be funny
