MSD Closed Loop perfect!
Old May 30, 2008 | 08:30 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default MSD Closed Loop perfect!
Installed the closed loop conversion from MSD and look at this CO readings!! With the old chip and greens it was set at 3.5% to let it pass the MOT. But only at a higher CO value it would run ok.
Now with this new chip and closed loop it runs like a dream all through the revs, very low CO at idle and a great fuel consumption!
Thanks a lot you guys from MSD!!
http://s261.photobucket.com/albums/i...current=CO.flv
Old May 30, 2008 | 08:33 AM
carlo's Avatar
carlo
Another happy MSD customer nice one stu
Old May 30, 2008 | 10:10 AM
XRT_si's Avatar
XRT_si
How easy and whats invlolved in installation? Sounds very good, 1st mod ill be doing I think
Old May 30, 2008 | 10:25 AM
Jasesapphy's Avatar
Jasesapphy
i have a P8 with closed loop and coil pack for sale in parts on Blacks, with injectors and lamba, best mod i made when i had a cossie
Old May 30, 2008 | 10:59 AM
XRT_si's Avatar
XRT_si
I was very tempted by yours but I already have L8 and yours is a different spec so the chip would be wrong.
Old May 30, 2008 | 03:24 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Well, you need a L8 ECU (saph4x4), the right MSD closed loop chip for your conversion and a lambda sensor. Other parts will remain the same as you already have put in. (like for instant greens or greys, 3 bar mapsensor etc.)
And it sooooo easy to setup. The software does almost everything for you. And you'll get a clear manual with the chip from MSD, it all speaks for itself.
Old May 30, 2008 | 03:26 PM
Andreas's Avatar
Andreas
What CO are you running now on idle? I havent tried my chip at the MOT-station yet and we have 0,5% CO-limit.
Old May 30, 2008 | 03:28 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
never knew you can do closed loop on P8 what about if its running pectel boards ?
Old May 30, 2008 | 04:33 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it came from the facory with closed loop!
Old May 30, 2008 | 05:25 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
......think a saff can get away with 6%...........just cheched mine yesterday and it's 1.9%.............without cloosed loop
Old May 30, 2008 | 05:27 PM
bigchez's Avatar
bigchez
Karl's set mine to 3.5 (or so it says on the bill!) I have the MOT in 2 weeks - will it pass?
Old May 30, 2008 | 05:28 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
closed loop will normaly idle at 0.90%...
Old May 30, 2008 | 05:36 PM
JTECH James
Passion for Fords!
lets hope its just under 3.50% .....
3.51% on a pre 92 car will fail
Old May 30, 2008 | 05:39 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
mine used to be 2.5% with P8 and greys, no closed loop
Old May 30, 2008 | 05:41 PM
crash_ash's Avatar
crash_ash
got my chip in the post yesterday! can't wait.
on greens mine would only idle happily around the 5% mark
Old May 30, 2008 | 05:43 PM
Andreas's Avatar
Andreas
Not in here in Sweden where the green top Sapph have to stay below 0,5% CO.
JTECH James
Passion for Fords!
crap chip or setup then!
any non closed loop car should aim for 2.5%....
Old May 30, 2008 | 05:45 PM
JTECH James
Passion for Fords!
at idle? or fast idle? stus stuff could easily make that...and you could use a sport cat and piss cat tests at any power level
Old May 30, 2008 | 06:02 PM
LHD220Turbo's Avatar
LHD220Turbo
i set mine up as per stu instuctions and its between 2.5-2.7% at idle i'm on l6)
if i was to go L8 and closed loop will i need to change the chip? i guess i would?
Old May 30, 2008 | 06:06 PM
JTECH James
Passion for Fords!
yes you would mate, but its worth it for 38mpg when pottering about
Old May 30, 2008 | 06:07 PM
LHD220Turbo
cheers
Old May 30, 2008 | 06:34 PM
pete mcrash
...........see my mot'er told me if it doesnt have a cat then it doesn't really matter......but aslong as it's 6% or less it will pass..........?????........
Old May 30, 2008 | 06:35 PM
JTECH James
Passion for Fords!
bollocks! the legal limit is 3.5%
where is it you get mots?
Old May 30, 2008 | 06:39 PM
LHD220Turbo
to be fair i thought the legal limit was 3 not 3.5, so happy days
Old May 30, 2008 | 06:41 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the MOT limit is not necessarily what you should be running it at though, 3.5% is not the cleanest way to idle your engine and give oil and spark plug longevity
Moonstone Mo's Avatar
Moonstone Mo
what sort of figure is it to get this done?
Old May 30, 2008 | 06:42 PM
JTECH James
Passion for Fords!
not at ll! infact 3.5% is way way more than any well set up car should ever need!
Old May 30, 2008 | 06:47 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
As you can see on the little movie that I have enclosed its now between 0,5-0,9% CO.
Same here in Holland. If the car does have a catalystic convertor and lambda sensor fitted new from factory (the green top ones, I think it's 'U9' on the car papers in Holland) then the limit is 0,5% CO.
I dont know if this value will go any lower with the MSD closed loop conversion. I havent tried to adjust the CO screw to see if it can see that value. Maybe best to ask Stu.
But If it is possible to go below the 0,5% CO then I dont know how precise it will stay there. My car has a value from somewhere 0,5% min to 0,9% max at idle, again see the movie.
Old May 30, 2008 | 06:52 PM
foreigneRS's Avatar
foreigneRS
Testing the future
this may be wrong, but is my understanding:
you won't be able to go lower using a narrow band lambda sensor, as it 'switches' the fuelling alternately slightly rich and lean around the 'ideal' mixture.
the only way to reduce the CO further is to have a catalytic converter
if you used a wide band sensor, it would theoretically be possible to change the point at which the mixture 'homes in' on.
Old May 30, 2008 | 07:01 PM
JTECH James
Passion for Fords!
yeah, ii found if weaker than 0.90 as stu recommends, they pick up on lambda fuelling, and surge at idle...
Old May 30, 2008 | 07:13 PM
pete mcrash
......just rang him..............yes it is 3.5%.........but he said to me it didn't matter if it was 6% it would still pass..........i just got the wrong end off the stick..............doh..........sorry mr tech.....we cant argue tonight....
Old May 30, 2008 | 07:15 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
..., they pick up on lambda fuelling, and surge at idle...
Can you explain what you mean by this?
Old May 30, 2008 | 07:18 PM
JTECH James
Passion for Fords!
can i have the garage name?
Old May 30, 2008 | 07:22 PM
JTECH James
Passion for Fords!
well, the lambda sensor controls fuelling under these conditions by switching from rich to weak, my cossie if weak, the idle speed would rise and fall in time with the rich weak cycle...
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
Another happy customer, great news.
Old May 30, 2008 | 07:27 PM
pete mcrash
......why would u want my pals garage name when u live 400 fuckn mile away.........
Old May 30, 2008 | 07:35 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Thanks for your answer! I now understand what you mean. Although it looks like mine has a little less then 0,9CO% reading at idle, its hasnt got this problem.
JTECH James
Passion for Fords!
pete...
because i work for vosa, and would like to take his testers licence off him...
Old May 30, 2008 | 07:37 PM
pete mcrash
pete...
................u really need to get out more........
Old May 30, 2008 | 07:41 PM
JTECH James
Passion for Fords!
he needs to learn to test to the given standards...not his own....
