MSD Closed Loop perfect!
Old May 30, 2008 | 07:58 PM
  #41
JTECH James's Avatar
JTECH James
Passion for Fords!
actually, stupid me! i already know where he is, who he is...
all i need to do is type your reg number in at work,and it will tell me, who,where when it was tested
Old May 30, 2008 | 08:03 PM
  #42
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
u crack on............................then U can come and test my car if u like...just to see if it passes..........
Old May 30, 2008 | 08:06 PM
  #43
JTECH James
Passion for Fords!
oh, it wont be me, too far away
Old May 30, 2008 | 08:09 PM
  #44
pa_sjo's Avatar
pa_sjo
Colossal Pervert
What a big man...
Old May 30, 2008 | 08:24 PM
  #45
glancy2081's Avatar
glancy2081
JTECHSAPH are you being serious about this surely not
Old May 30, 2008 | 08:26 PM
  #46
JTECH James
Passion for Fords!
no...im winding pete up.
dont tell him though
Old May 30, 2008 | 08:27 PM
  #47
pete mcrash
............................................(we do this from time to time)
Old May 30, 2008 | 08:28 PM
  #48
glancy2081's Avatar
glancy2081
a was going to say you seem like a decent bloke and as not as if its risking anyones life and dangerous.unless standing behind it when its running maybe lol
Old May 30, 2008 | 08:31 PM
  #49
JTECH James
Passion for Fords!
i could, so pete, tell your mate he will get caught one day...its his licence he will loose and maybe his job,is it worth it? to let another poorly setup car carry on.....
no!
Old May 30, 2008 | 08:46 PM
  #50
pete mcrash
no!
......err no he wont cos like i said my car idels at about 1.90% so he's done fuck all wrong...........
Old May 30, 2008 | 08:50 PM
  #51
JTECH James
Passion for Fords!
you said if its below 6% he would pass it....so he probably has done wrong at some point...or is prepared to...
or he would have said if its below 3.5%it passes...
what else does he "let go"? fookin stupid imo
people like that think there doing you a favor...id rather have my car tested to higher standards so i know its better than ok
Old May 30, 2008 | 08:53 PM
  #52
Dicko&Vacant's Avatar
Dicko&Vacant
cat fight
miaowwwwwwwwwwwwwwww
mcrash for the winner
Old May 30, 2008 | 09:07 PM
  #53
gym-rst's Avatar
gym-rst
Probably just trying to get rid of an arsey customer. Lmao
Old May 30, 2008 | 09:18 PM
  #54
pete mcrash
......c u jimmy............away ta fuk......
Old May 30, 2008 | 11:59 PM
  #55
captiva's Avatar
captiva
Originally Posted by YBJ
Installed the closed loop conversion from MSD and look at this CO readings!! With the old chip and greens it was set at 3.5% to let it pass the MOT. But only at a higher CO value it would run ok.
Now with this new chip and closed loop it runs like a dream all through the revs, very low CO at idle and a great fuel consumption!
Thanks a lot you guys from MSD!!
http://s261.photobucket.com/albums/i...current=CO.flv
What sort of fuel consumption did you get before and after fitting closed loop?
Old May 31, 2008 | 05:45 AM
  #56
MARCOSWORTH's Avatar
MARCOSWORTH
Good to see it runs fine now Wim
Hopefully i get my new chip today from Stu and install it
Old May 31, 2008 | 05:51 AM
  #57
Turbosystems's Avatar
Turbosystems
Super Moderator
Originally Posted by Turbocabbie
never knew you can do closed loop on P8 what about if its running pectel boards ?
closed loop lambda control is standard on a p8 as is closed loop boost control etc etc.if you have a pectel board lambda control can be activated or deactivated,as can wasted spark .The p8 can run wasted spark as standard
Old May 31, 2008 | 06:53 AM
  #58
YBJ's Avatar
YBJ
Thinking Cosworth..
I havent got it calculated at this moment, but it seems a lot less. Before it would do 1 liter to 9,5km and now looks like more than 1 liter to 12-13km.This is of course when cruising on the highway, but untill now I havent driving for more than 100 miles with the new conversion. But as soon as I have done a good measurement I will post it for sure.
Old May 31, 2008 | 06:54 AM
  #59
YBJ's Avatar
YBJ
Thinking Cosworth..
Hi Marco, also going closed loop? See you next week at Lelystad?
Old May 31, 2008 | 07:46 AM
  #60
Some PRE92 cars have NO EMISSIONS test, other than OPPULANCY TEST, smoke test in normal language, and I thought here was a 4.5% limit for one age of car as well.
Old May 31, 2008 | 11:22 AM
  #61
MARCOSWORTH
I allready had closed loop but for a .63 now i get one for the .48.
Not sure about Lelystad next week,hopefully yes
Old May 31, 2008 | 12:35 PM
  #62
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Pre-86 is 4.5%
Old May 31, 2008 | 05:24 PM
  #63
YBJ's Avatar
YBJ
Thinking Cosworth..
Originally Posted by pa_sjo
Pre-86 is 4.5%
I think it maybe can be different from country to country.
- Overhere in Holland its 4.5% till 1991.
- From 1991-on its 3.5%.
- But cars fitted with cat and lambda control only may have 0.5%.
- And then from 1994-on there came newer regulations for petrol engines which says to meet certain Euro emission standards with a 4-gas test. 0,5% at idle and 0,3% max. at 3000rpm, lambda between 0,97-1,03.
Mark RS
Mar 5, 2021 06:08 PM
AJC
Oct 1, 2015 06:47 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
20/20 vision
Sep 29, 2015 09:25 PM
