escort cossie indicator prob..
what would cause the indicator stork not automatically retract sometimes?? will i need a new indicator stork? or could it be electrical fault?
As said the reverse side of thw wheel has a notch into which the lug of the plastic self canceller sits so it rotates with the wheel, this canceller has further "foot/lug" that physically pushes the indicator switch off as it hits the bit that sticks out from the switch when activated.
This is why you have TWO clicks one when the "kick off" lug goes past as wheel is turned and one when the wheel is then turned back and it clicks off, just take wheel off and have a look you will soon see.
