Will an Ahmed "grey" chip start an engine on 750cc siemens??
I'm trying to get my engine started but my new chip hasn't arrived yet so will an Ahmed chip that ran Bosch greys start up and engine on 750cc siemens injectors. I don't want to drive it, I just want to get her started and running.
cheers.
cheers.
it will run if you set the overhead valve diferentiating turbo injectors forward thrust bearing to run at around 3 times it's normal output. or you could try mounting the limited slip disributors inverted crank radiator to allow more air into the filtration system....
failing that,
adjust the Flux capacitor that'll get her started!!!
failing that,
failing that,
failing that,
![tiff](https://passionford.com/forum/images/smilies/punchballs.gif)
big_Rad
15-09-2017 09:36 AM
Zoggon
10-08-2015 10:39 AM
CabrioTurbo
01-08-2015 11:04 AM
