Wanted Please !!!
Old May 19, 2008 | 06:00 PM
VicRS500's Avatar
VicRS500
Not a very good poster
Exclamation Wanted Please !!!
Hi ya guys and gals on pf
I am in need of a FORD KA FRONT DIFFERENTAIL (cheap).
As my one has started to leak fluid badly so need it asap
thanks.
PM ME OR POST BELOW
cheeRS
From
Vicrs500
xxxx
Old May 19, 2008 | 06:09 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
a gearbox then?....
the diff is built into the gearbox.....
Old May 19, 2008 | 06:13 PM
VicRS500's Avatar
VicRS500
I told it up to my ford man today he sed it is just the differentail as it is coming for the front passengers side do not think it is the whole gear box just the differentail
xxx
Old May 19, 2008 | 06:20 PM
groomers's Avatar
groomers
sounds like it is prob just the diff side seals any way these gear boxes split real easy so instead of buing a new one just re-seal it surely?
Old May 19, 2008 | 06:21 PM
JTECH James
Passion for Fords!
the diff is in the gearbox....
if its leaking, it will be through a driveshaft seal, which is an indication your diff bearings are worn
Old May 19, 2008 | 06:27 PM
VicRS500's Avatar
VicRS500
what happens if i re seal it and it is the bearing that is worn what will happen if it gets driven alot then
xxx
Old May 19, 2008 | 06:32 PM
JTECH James
Passion for Fords!
it will be ok for a week or so then leak again..
the diff moves about due to worn bearings, which wears the seals out on the driveshafts....
you may be ok just changing the driveshaft seals if you dont have bearing play, but imo its normally the case.
does your speedo work ok?
Old May 19, 2008 | 06:46 PM
groomers's Avatar
groomers
also can leak if the shaft has been out
Old May 19, 2008 | 08:17 PM
VicRS500's Avatar
VicRS500
Thanks For Ya Help All Sorted Now Getting It All Fixed Tomorrow Wow
But I Do Thank All U Pf's Lads He He Lol
Xxxxxxx
moesin2005
Jan 23, 2022 06:28 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
rog
Aug 30, 2015 05:32 PM
Ben26
Aug 27, 2015 08:56 PM
adriansaleem
Aug 3, 2015 11:21 AM
