2wd Sapphire Cosworth Sensor locations
engine coolant temperature sensor, Right hand side of the head as you look at it under the inlet manifold
air charge temperature sensor, Inlet manifold I think
water temperature sender. Left hand side of the head as you look at it near the front.
As above coolant temp sensor for ECU, at REAR of head under the water pipe you can see going into the the head, battery side of the car, this is for the ECU, NOT the temp gauage.
This will have a TWO pin connector going to it.
The temp GAUGE one is at the front of the head, on the turbo side just forward of the turbo, identified by it's SINGLE wire and 90 degree rubber boot terminal.
AIR TEMP SENSOR, middle of plenum cover pointing towards the inner wing with a TWO pin plug going to it, the ONLY electrical thing there.
