what are these called
18-05-2008, 08:01 PM
Baby Cheesus
and can you get them with a 1/8 bspt thread?
i need about 12 of em
18-05-2008, 08:04 PM
Passion for Fords!
there called air jobbies
i think mike rainbum sells them,
however, i wouldnt advise asking mike for an air jobbie
heaven knows what you might get
18-05-2008, 08:13 PM
Live long and prosper!!
Don't know if this will help but the cossie intake plenum uses 1/8 npt threads only one tooth out from 1/8 bsp
A useless bit of info that i found out last week
Paul
18-05-2008, 08:14 PM
Frog Tosser
any compressed air or hydraulic place sell them, hose tails
18-05-2008, 08:15 PM
Baby Cheesus
cheers paul, i know the cossie ones use a npt thread, as my old man currently has my inlet to drill and tap some holes, but he cant get an npt tap lol
Baby Cheesus
Quote:
Originally Posted by
teamfatboy
cheers dude
18-05-2008, 08:20 PM
Baby Cheesus
or are these any good?
http://cgi.ebay.co.uk/PNEUMATIC-FITT...2em118Q2el1247
i basically want them to make a vac manifold for the roller barrels, so will have 4 take off on them, to join 4 on the vac mani, and then 3 or 4 takeoff from that for fuel press reg, ext w/g and map sensor. and anything else i cant think of lol
18-05-2008, 08:23 PM
18-05-2008, 08:24 PM
Frog Tosser
only good if you are using rigid hose, and they are expensive
as everyone else already said... definitely called hose tails
18-05-2008, 08:33 PM
Fudgey
I had to borrow one from my engineering place
only had a bsp one
They will be no good imo try pirtek tommorrow there by farepak down the end on the right
Paul
18-05-2008, 08:36 PM
Resident Wrestling Legend
they may be, depends on what sort of fitting you are going to fit into the female end of them
18-05-2008, 08:49 PM
Baby Cheesus
costina
only had a bsp one
Paul
will try and get over at the weekend mate, working in cunting plymouth tomoz
Baby Cheesus
dojj
will just be them ones, with the solid hose
19-05-2008, 04:53 AM
60p each from PARKERS.
19-05-2008, 06:09 AM
if you really get stuck, machine mart also do them
19-05-2008, 09:01 AM
stevecfrst1
30-09-2015 05:18 AM
rsguy
44
29-09-2015 03:29 PM
IainRS1700T
25-09-2015 06:44 AM
oilman
Trader Parts for Sale.
23-09-2015 11:21 AM
