Go-tech question.
Old May 17, 2008 | 10:37 PM
biglee's Avatar
biglee
Audio specialist
Default Go-tech question.
does anyone use this on their RST? and does any of the go-tech managment systems do away with the awful metering unit??
i know the go-tech can make use of the original hall effect sensor but other than that i would like to know more...
anyone?
Old May 17, 2008 | 11:13 PM
c.fogarty's Avatar
c.fogarty
Currently fitting Gotech Mini X to my S2.
All the Gotech ECUs do away with the M/Head, Injectors etc.
The basic Gotech MFI & the Mini X are the only two which can use hall sensor if you wanna stick with a Dizzy
(Mini X can also run coilpack with a crank sensor fitted)
Obviously have to change to electronic injectors. With an EFI head just fit an EFI inlet manifold/fuel rail/fpr or, as I have, you can modify MFI inlet to take injectors with frst fuel rail/fpr.
Fuel lines are a doddle to sort, and all in, is probably the easiest/cost effective way to go EFI.
TPS, Dizzy, Water Temp, ACT, Coil and injectors wired up & your away.
Any questions just PM mate
Old May 17, 2008 | 11:19 PM
biglee's Avatar
biglee
Audio specialist
awsome, thanks for the reply, exactly what i was looking for,
i will PM you with some questions if ok..
thanks again
Marino
Sep 12, 2015 11:10 AM
Bransby
Sep 11, 2015 01:09 AM
s1turboman
Aug 29, 2015 04:27 PM
Marcus L
Aug 29, 2015 02:18 PM
leep27
Ford Mondeo Including ST
Aug 22, 2015 01:52 PM
