Laptop/Computer experts help please
Old May 16, 2008 | 08:51 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Laptop/Computer experts help please
Just bought myself an early Windows 98 equiped Compaq 1635 laptop for mapping and data logging.
It's in as new condition and all works fine except.. It has a floppy drive and a CD drive but when I go into 'my computer' it only shows the A drive (floppy) and C drive but not the CD drive, I have tried inserting a CD and the light on the drive illuminates and the cd whizzes round but nothing comes up on the screen.... Any ideas??
Old May 16, 2008 | 08:54 AM
Paulo P's Avatar
Paulo P
Sounds like the cd drive is knackered
Old May 16, 2008 | 08:58 AM
Martin-Hadland
If that was the case I would have thought it would still display the 'D' drive icon in 'my computer' section and simply not work when clicked?
Old May 16, 2008 | 08:59 AM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
sounds like the driver to the cd has disapeared.
Have u tried going on compac homepage and downloading a new driver?
Also THURALY check it for viruses before you go on
Paulo P's Avatar
Paulo P
Depends if it can see the drive or not.
Old May 16, 2008 | 09:02 AM
foreigneRS's Avatar
foreigneRS
Testing the future
can it be seen in device manager?
Old May 16, 2008 | 09:03 AM
Martin-Hadland
Where do I find that?
Old May 16, 2008 | 09:05 AM
Paulo P's Avatar
Paulo P
control panel > system > hardware > cd/dvd drives
Old May 16, 2008 | 09:07 AM
Martin-Hadland
It's not listed in the Device Manager..
Old May 16, 2008 | 09:08 AM
dvid's Avatar
dvid
Can you remove it from laptop and re-insert it and see if it picks it up? should be a release catch on the side / bottom
Old May 16, 2008 | 09:13 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
you have probably found the reason why it was sold by the previous owner lol
Old May 16, 2008 | 09:14 AM
Martin-Hadland
I think it's secured internally..
Here's the device manager screen... Whats the two yellow exclamation marks for??
Old May 16, 2008 | 09:16 AM
Martin-Hadland
It's not a problem, I bought it barmy cheap to replace exactly the same type with a faulty floppy and riffy casing. I can make one out of the two if needed.
Old May 16, 2008 | 09:17 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i'm no expert at all, just messed around a bit at home, but this is what i'd do:
if it's not in device manager then it needs to be. as said, try reconnecting it, although it sounds as if it is connected otherwise it wouldn't spin up etc.
if that doesn't find it, right click in device manager and scan for hardware changes to see if it picks it up. if it finds it, it will either automatically install the driver if present (unlikely, or it probably would have done it by now) or you will have to install it.
if it doesn't find it, you may be add it manually by going to 'add hardware' in the control panel.
also, on boot up it should be found in the BIOS before windows loads. you should get a prompt like 'F11' or something when you first fire it up that takes you into the BIOS. go in there and see if it can be found
EDIT - the yellow exclamation marks are because those bits of hardware are not working properly. maybe just need drivers re-installing or maybe a hardware fault
Old May 16, 2008 | 09:19 AM
Turbosystems
Super Moderator
laptops are inherantly difficult to fix most people seem to have accidently dropped them and claim on their house insurance
Old May 16, 2008 | 09:24 AM
JohnnyB's Avatar
JohnnyB
Its windows 98 so there is your main problem. there is a option in the control panel to scan for new hardware as 98 will sometimes, not auto detect.
Old May 16, 2008 | 09:26 AM
JohnnyB's Avatar
JohnnyB
ps I would download the drivers from the Manufactures web site.
That seems to be the problem
Old May 16, 2008 | 10:24 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
I reckon you need to sort out those exclamation marks first on those hardware devices. They are the controllers for the hard disk & CDROM drives. Fix them & you'll probably find the CD drive will then show up & work.
Download the motherboard drivers from the Compaq website - what model is it?
Old May 16, 2008 | 03:25 PM
Martin-Hadland
Spot on that man It's now sorted, it turns out that when I originally booted it up the battery was flat and it died almost straight away so I plugged it into the mains and tried again but for some reason it didn't boot up properly.. One re start later and it's sorted.
Pectel datalogger loaded and working
Thanks for all the help guys
Old May 16, 2008 | 04:45 PM
AndyCanning's Avatar
AndyCanning
if you ever get the yellow exclaimation marks in device manager .. they have to be sorted first really as it effects the day to day running of the machine and causes faults with other parts.
most of the bits i get are from www.pcrus.co.uk incase
DavidK
Sep 27, 2015 02:55 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Mark Mawson
Aug 31, 2015 07:09 PM
puntoturbo
May 4, 2005 02:10 PM
21
Sep 4, 2004 09:27 PM
