egt sensor
Old May 12, 2008 | 06:38 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
Default egt sensor
wheres the ideal place for it? can i put it in the front pipe close to the turbo? its a split pulse manifold so if it goes in the manifold it will be in either 1+4 or 2+3
Old May 12, 2008 | 08:55 PM
NEEDFORSPEED
up
Old May 12, 2008 | 09:02 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
it´s always best to have one in each cylinder, but most do have it in the collector in a 4-1 manifold so it measures all 4.
But in a split pulse i would put it in the one where cyl 3 is, cause it´s always the hottest one.
Old May 12, 2008 | 09:04 PM
NEEDFORSPEED
if i could afford to have 4 i would along with 4 lambdas and a much more adaptive ecu to run them! no good in the front pipe then?
Old May 12, 2008 | 09:32 PM
DazC's Avatar
DazC
It will be fine in the front pipe but will only read a collective temperature of all 4 ports (so an average).
I can't see individual cylinder problems arrising on your mountune plenum to make much of a difference though.
Old May 12, 2008 | 09:34 PM
NEEDFORSPEED
cheers daz its going in the front pipe with the lambda then!! much easier for me!
Old May 12, 2008 | 09:43 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I was going to ask this as I want one for mine.
What about if the probe snaps/breaks... Turbos gonna get munched? Could you not put it in the downpipe as close to turbo as poss?
Old May 12, 2008 | 09:49 PM
NEEDFORSPEED
yep thats what im doing putting it in the front pipe / down pipe (same thing) next to my lambda which is already rite at the top close to the turbo. i wouldnt say there was any chance of anythin going wrong with it even if it was before turbo as theyre rated to rediculous temps even if you had als on for long periods of time! what make guage you gettin?
Old May 12, 2008 | 10:13 PM
Charlie Chalk
Unknown.
Not sure yet, Depends also if I decide on a manifold so will prob mount it there, but failing that it'll go in the downpipe if I stay cast manifold.
Old May 13, 2008 | 12:05 AM
xr4x4rs's Avatar
xr4x4rs
i have mine after the turbo in the downpipe mate
Old May 13, 2008 | 06:04 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Depends on what you're trying to measure? "EGT" should be as close to the exhaust valve as possible, "pre turbine temperature" should be as close to the turbine inlet as possible, anything after the turbo is guesswork and academic.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
