Disconnecting Amal Valve
26-10-2004, 10:55 AM
Which wire is the amal valve on an esc cos?cos there are 3 that are near the same thingy lol....and is it best to disconnect this becuase of a superchip?
26-10-2004, 11:07 AM
PassionFords Creator
26-10-2004, 02:17 PM
sorry for the late reply stu, its a small turbo 95.
26-10-2004, 02:24 PM
Small turbo Amal should be unplugged completely if running most chips as they couldnt figure out how to stop it clicking and going mad so their professional "Fix" was to remove the power from it... roflol
The valve is located underneath teh slam panel ahead of the thermostat housing. Its also a pig to unplug
26-10-2004, 02:26 PM
clicking?what clicking cos thats what my engine doin at the minute...
26-10-2004, 02:27 PM
Amal valve pal.
Unplug it and you should find its ok, but get the boost carefully in case some goon has set the boost with it plugged in
26-10-2004, 02:29 PM
so its a lead i gotta pull out
26-10-2004, 02:31 PM
Quote:
Stu @ M Developments ,
The valve is located underneath the slam panel ahead of the thermostat housing. Its also a pig to unplug
Yes pal.. find this device as above and remove the plug from it...
there are 3 leads there,which one do i pull out?
Did Someone Mention TUV
the power lead to the amal valve mate yes
26-10-2004, 02:34 PM
Sounds like your in teh wrong area fella...
Its bolted to teh top of the intercooler, but its obscured by teh slam panel if that helps?
26-10-2004, 02:35 PM
yeah thats where i am,altho there are 3 leads that all end up in the same place.
26-10-2004, 02:36 PM
The valve in question has 2 pipes connected to it and 1 single 2pin plug mate....
26-10-2004, 02:39 PM
aye thats the one, fookin thing wont come out
26-10-2004, 02:40 PM
that y stu said its a pig to un-plug
26-10-2004, 02:41 PM
Glad its not just me that struggles with em.. watch you dont pull the whole valve apart
26-10-2004, 02:43 PM
nearly pulled my hand off there tryin to pull the thing out,its still on and it wont shift....bloody fords.
26-10-2004, 02:47 PM
Its got a clip on... same plug as your injectors
26-10-2004, 03:03 PM
nice one buddy,thats it now...how many turns,or half turns would you recommend to turn the boost up until i get it setup in a matter of a day.
26-10-2004, 03:07 PM
I wouldnt
26-10-2004, 03:12 PM
26-10-2004, 03:38 PM
Noooooo, not worth the risk
27-10-2004, 11:58 AM
surely,if i turn it a tiny bit,take it for a drive i can see where my car is boosting to....it seems that as standard its holding half way round the solid bar....
27-10-2004, 12:04 PM
Is your fuel pump still flowing perfect pressure and your fuel reg still maintaining that pressure with boost against it?
27-10-2004, 12:19 PM
ehhhhh i dunno.....so dont touch it then lol.
27-10-2004, 12:24 PM
Skiman , as I said not worth the risk..I've blown up a small turbo cossie engine (holed no 4 piston)........Expensive mistake £ 2,600 to put right
Wished I had got it checked out first - just like Stu is advising you
27-10-2004, 12:28 PM
Right, im not touching it then....
27-10-2004, 01:24 PM
Quote:
good idea. everyone is boost happy until they put a hole in or melt a piston
steve.rst
15-03-2016 08:01 AM
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
rs_jim
19-09-2015 08:41 PM
